Author: Subject: zx12r gearbox
eccsmk
posted on 28/4/11 at 10:04 PM Reply With Quote
zx12r gearbox
my indy has developed a very high pitch whine when using 5th and 6th gears
after a bent gear rod caused me to miss gears
does anyone know if it could be selector forks or is it likely to be something more serious?
im checking mainly because id like to keep using it and strip over winter
thanks locosters
belgian2b
posted on 29/4/11 at 09:09 AM Reply With Quote
Hello,
I have broken my zx12 engine and rebuilding a new one.
Both engines came from crashed bikes.
The new one had 2broken teeth on a gear pinion and the old one had serious marks on gear pinions.
This probable came from the shock on the pinions when the wheel suddendly stops.
I am not a specialist, but it seems that gear pinions may be a weakness in those engines.
In your place, i think i would at least change the oil and check for any metal parts in it.
Gerardo
eccsmk
posted on 29/4/11 at 11:34 AM Reply With Quote
oil has been dumped and there are signs of metal in it altho such a tiny amount i think im going to brave it and run the car til winter
thank you for the advice
