snippy
posted on 1/5/11 at 10:08 PM |
Air Filter for bike carbs
Having now fitted bike carbs to my Zetec engine I was looking at buying a Pipercross Sausage filter or an equivalent make. I was looking at such a
filter and its backplate at the Stoneleigh show today but sizewise they are way too big to fit to bike carbs. What have others fitted to their bike
carbs as air filters? Where can I get a proper bike size sausage filter for example? Thanks.
Nick
Craigman9
posted on 2/5/11 at 06:26 AM |
A fellow locoster told me to buy some frying pan mesh from wilkinson for £1 and secure that over the inlets. I have used it ever since and it has
worked perfectly well ![](/images//smilies/bigsmile.gif)
cliftyhanger
posted on 2/5/11 at 07:22 AM |
Nooooooo
Don't cover the inlets with mesh, it is very restrictive and kills power and airflow. If you want to check yourself, stick it on the rollers
with and without the mesh, but that has been done many times.
Unless the mesh is used to create a huge airfilter type thing, in which case get one that filters the air.
Now, sizewise, do you mean they are too deep? Or too long/tall?
tul214
posted on 2/5/11 at 07:26 AM |
Pipercross do the PX500 series that is only 370mm long.
1.6 Raw Super6 sold
posted on 2/5/11 at 09:25 AM |
quote: Originally posted by cliftyhanger
Nooooooo
Not only that, it doesn't filter anything but large rocks out either so it's the most useless possible combination.
The Pipercross sausage filters are available in three lengths, the PX500 and PX550 are 370mm long which doesn't seem overly large for a car
engine. The PX600 which is maybe what you saw at Stoneleigh is 435mm, and the PX650 is longer again.
I'm not sure what you mean by "too large" though, I can understand having problems fitting it to the TBs if it was too small.
[Edited on 2/5/11 by MikeRJ]
macc man
posted on 2/5/11 at 09:40 AM |
Px500 will fit under the bonnet of most 7 type cars if yo do not make the manifold too long.
Craigman9
posted on 2/5/11 at 10:26 AM |
I am back from work in 4 weeks time, think I might have to make some modifications after reading this!
snippy
posted on 2/5/11 at 03:55 PM |
Maccman - if that is the PX500 in your picture then I reckon that will fit a treat. It also looks to be thin enough as I don`t want anything more than
60mm thick. I saw an ITG sausage filter at Stoneleigh today which was the right length but too thick at 90mm. I`ll look into the PX500 more. Thanks
guys.
