joemotion
posted on 2/5/11 at 11:30 AM |
Sierra hub caliper seals
Hi does anybody know where to get the seal from for my sierra hub caliper? mine has been damaged - could possibly do with the one to the rear of the
caliper as well - all help appreciated!
Uploaded with ImageShack.us
[Edited on 2/5/11 by joemotion]
mcerd1
posted on 2/5/11 at 11:55 AM |
the seals come with the bearing kits
joemotion
posted on 2/5/11 at 12:08 PM |
cheers
right further help then - i have push in shafts from an 88 sierra 1.8 CVH and bearings look like this -
any ideas where to locate one from?
Joe
joemotion
posted on 2/5/11 at 12:14 PM |
or find out the part no?
Davg
posted on 2/5/11 at 12:33 PM |
as long a you go for a non abs sierra model you will most likely be ok, ie 1.8. or 1.6. ant decent motor factors will help you out, take the old
bearing with you to double check. Bearing number will possible on the edge of the bearing SKF or FAG or the like.
cheers D
joemotion
posted on 2/5/11 at 12:39 PM |
cheers - gonna pop up now!
joemotion
posted on 2/5/11 at 03:09 PM |
sorted
