Trev Borg
| posted on 11/5/11 at 07:06 PM |
Rover T16, a little help please
Bought a T16 engine a couple of years ago, and have never got round to doing anything with it, so now might be the time.
Firstly I don't seem to have a wiring loom, so if anyone has a spare it would be nice
Second, I don't know if the ecu's are locked or not. Anyone know?
What am I going to need to see if it starts?
Does anyone know what wires are required from the loom?
chears
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
| posted on 11/5/11 at 07:29 PM |
T series with MEMS ecu ?
Ecu is coded to the security module and engine you would need to get the ECU neutered.
If you connect it without disarming it will start once only then won't restart until you disconnect the battery the ecu resets and it
will start once only again.
Humbug
| posted on 11/5/11 at 09:16 PM |
Didn't Robin Hood have a kit with a T16 for a while? Might be worth looking on RHOCAR?
hillbillyracer
| posted on 11/5/11 at 10:04 PM |
Would early T series MEMS ECUs not be coded then? I ran a N/A T series in my grasser & it was easy to get going, there only was 5-6 wires outside
of the harness between the engine & ECU that were needed. I just pulled it all out of a car in the scappy, got a wiring diagram from the dealer
(Rover were still in business) & worked out what was needed. I remember an Earth, Permament live, Ignition live, Starter signal & Fuel pump
output live.
| posted on 13/5/11 at 07:19 AM |
output live.
That would have to be a very very early T16 series if not the M16 series ...
