Author: Subject: Best way to remove old gasket material ?
givemethebighammer
posted on 19/7/04 at 09:15 PM Reply With Quote
What is the best way to remove old exhaust gasket material from an aluminuim head. The old crap looks like a mixture of exhaust paste type stuff and something paper like (probably not paper but looks like it).
I really don't want to damage the head.
thanks
Viper
posted on 19/7/04 at 09:17 PM Reply With Quote
There is a spray on gasket remover on the market (can't remember the name) much safer than scrapeing...
givemethebighammer
posted on 19/7/04 at 09:24 PM Reply With Quote
just what I need just need the name of the stuff now or would something like thinners do the job ?.......anyone.
thanks
givemethebighammer
posted on 19/7/04 at 09:30 PM Reply With Quote
this looks like the stuff !! . I'll call a few motorbike shops etc in morning to try and locate some.
gjn200
posted on 19/7/04 at 09:52 PM Reply With Quote
Also known as chisel, made by loctite
<- Me!
gjn200
posted on 19/7/04 at 09:53 PM Reply With Quote
Oh, I think its only paint stripper like nitromors btw
[Edited on 19/7/04 by gjn200]
<- Me!
chris.russell
posted on 20/7/04 at 08:51 AM Reply With Quote
I use the loctite chisel stuff, works a treat! Spray on and leave for 20 minutes and the gasket all bar wipes off.
Caustion: Very flammable + us in a well ventilated area.
[Edited on 20/7/04 by chris.russell]
Mines a pint
derf
posted on 20/7/04 at 01:35 PM Reply With Quote
The easiest and most time tested way is to scrape it off with a hard sharp flat surface, I usually flip the engine upside down, take 2 chains and attach them to the bottom supports of my engine hoist (to keep the engine from moving), and lift the engine upside down, and scrape from there, then gravity take over when I start to scrape, no material in the block.
If you have a stong enough table leave the engine on the stand, and lift it on the table when it's upsidedown.
DaveFJ
posted on 20/7/04 at 01:50 PM Reply With Quote
Would NEVER support the use of a scraper... unless it was pespex (old trick works well.
Cheapest and easiest solvent to use (if your married) steal the wife's nail varnish remover ! as long as she doesn't catch you it's brilliant for these types of jobs and as she paid for it she can hardly say it comes off the 'locost budget'
Dave
Terrapin_racing
posted on 20/7/04 at 01:53 PM Reply With Quote
Acetone (nail varnish remover) available by the gallon cheaply from fibreglass suppliers
NS Dev
posted on 22/7/04 at 04:29 PM Reply With Quote
I use solvent and a scraper (very carefully!) all very well saying never use a scraper but in the real world you often have to! You want something very thin to get under the material rahter than actually scrape at it. I use a stanley knife blade held as parallel to the surface to be cleaned as possible, or a razor blade in a safety holder, again held very flat to the surface, works a treat and mechanically removes the bits that the solvent struggles with.
posted on 25/7/04 at 09:39 PM Reply With Quote
I've been using my old mans Snap On scraper, and it is quite simply amazing. It has a reversable tungsten tip that is actually slightly curved, and it makes removing stuborn gaskets without damaging the metal a piece of cake. I suspect it's probably quite expensive though, as is everything Snap On.
givemethebighammer
posted on 27/7/04 at 09:38 PM Reply With Quote
Finally solved ...
Nail varnish remover and fine wire wool and off it came.
thanks
