pekwah1
| posted on 24/5/11 at 06:53 PM |
Escort Ignition Wiring
Hi guys,
does anyone have any idea which wire is which on a mk4 escort ignition barrel?
This is what i have found so far:
RED = PERMANENT LIVE
BLUE/BLACK = LIVE ONLY WHEN IGNITION ON
BLACK = CRANK LIVE
YELLOW = ACC
i'm assuming 'crank live' is for the starter, what does 'acc' mean?
Regards,
big_wasa
| posted on 24/5/11 at 06:59 PM |
Acc, radio ect
omega 24 v6
| posted on 24/5/11 at 07:00 PM |
Usually "accesories"
it's usually live when the key is turned 1 click on. But no ign lights.
pekwah1
thanks, so there's nothing in a kit car that i'd require that for then i'm guessing.....!
why is this wire required anyway in a regular car?
omega 24 v6
| posted on 24/5/11 at 07:06 PM |
Unless you have a powerpoint/cigarette lighter then probably not.
On the fords the radio would be controlled by this position of the key. you would not have been able to turn the radio on without the key.
mcerd1
| posted on 24/5/11 at 07:07 PM |
so you can listen to the radio, without the ignition on
pekwah1
| posted on 24/5/11 at 07:08 PM |
sweet, well i was wondering how i was gonna 'live' my head unit, 6x9s, 2 15" subs, amp etc.....
that's a weight off!
omega 24 v6
| posted on 24/5/11 at 07:10 PM |
PMSL you chav
pekwah1
| posted on 24/5/11 at 07:11 PM |
well with that sorted, i picked up an awesome bodykit for the striker from halfords earlier, better go get fitting!!!
omega 24 v6
| posted on 24/5/11 at 07:16 PM |
Sounds bangin are you gonna slam it as well.
