Author: Subject: electronic led flasher relay
sdh2903
posted on 19/6/11 at 03:40 PM Reply With Quote
Im just about finishing up my wiring and am having a few issues with my indicators. Im using a 3 pin electronic flasher relay with led lights all round. I think that the relay is knackered. when the relay is working correctly i am assuming that the output from pin 49a should be a pulsed 12v? I am just getting 12v but then when all lights are connected just they don't light up at all.
The other pin on relay goes to the warning lamp so i tried the indicators using that output and this time every thing came on when selected (L, R and haz) but
just came on solid ie no flash? Am i right in thinking this proves my wiring is ok but flasher is duff ?
daniel mason
posted on 19/6/11 at 05:55 PM Reply With Quote
i would say you need a pair of diodes on the circuit. what hazard switch are you using?
sdh2903
posted on 19/6/11 at 06:49 PM Reply With Quote
Its a savage switch (hazard) with a rocker switch for indicators. Its wired with diodes, with a 12v feed every thing works as it should. I'm just not getting any pulsating voltage to make it flash. Think its got to be a duff relay.
RazMan
posted on 19/6/11 at 07:15 PM Reply With Quote
Have you tried substituting one or two LEDs for a conventional bulb as a trial? Sometimes LED setups can behave very strangely. Are you sure your diodes are wired correctly (polarity wise)?
Raz
sdh2903
posted on 19/6/11 at 07:57 PM Reply With Quote
Diodes are defo right way round first thing I checked. I will have a play with the conventional bulb in the morning.
I should still be seeing a pulsing voltage from the relay if working correctly though shouldn't I? It was loaded up with all the indicators, bar the side repeaters.
daniel mason
posted on 19/6/11 at 08:05 PM Reply With Quote
do you have a diagram of how you wired it?
your diodes should be on the left and right indicator wires where they connect to the hazard switch
sdh2903
posted on 19/6/11 at 08:09 PM Reply With Quote
Wired like this:
Hazard Wiring Diagram
daniel mason
posted on 19/6/11 at 09:34 PM Reply With Quote
dont think thats right mate! will take a look
daniel mason
posted on 19/6/11 at 09:46 PM Reply With Quote
first set of contacts
pin 1 feed to flasher
pin 2 permanent feed
pin 3 ignition feed
second set of contacts
pin 1 return from flasher.
pin2 left and right ndicator feed with diode on each letting voltage away from switch and not back
pin 3 not used
the only wire i cant remember was where i fed the indicator switch common from!
[Edited on 19/6/11 by daniel mason]
sdh2903
posted on 20/6/11 at 11:28 AM Reply With Quote
Ive bench tested the relay today and its definitly Fubarrred. When the new one arrives wiil take it from there. I think my wiring method works in the fact that every thing comes on when selected but just not flashing.
I will make a note of your connections tho incase it still doesnt work
sdh2903
posted on 21/6/11 at 02:54 PM Reply With Quote
It was a dodgy relay new one fitted and all works perfectly
For info the above diagram works using savage hazard switch and a toggle ind switch.
franky
posted on 21/6/11 at 03:32 PM Reply With Quote
better that way than pulling the loom apart
sdh2903
posted on 21/6/11 at 07:17 PM Reply With Quote
Did pull apart a lot of it as I was concerned it was my wiring rather than a brand new relay that was duff
