<<  1    2    3  >>
Author: Subject: FS: Aprilia-Engined Single-Seater Project
posted on 27/6/11 at 02:01 PM Reply With Quote
For sale due to a change of chassis and engine for my trike project!
SWIFT DB1 CHASSIS
Freshly Shot-blasted & Ready For Minor Repairs / Tweaks and Paint.
Front Wishbones, Links and Rockers
Rear Wishbones
Front ARB
Steering Rack & Clamps
Steering Arms
Pedal Set
Gear Linkage
Fuel Tank
Tank Surround Plate
GRP Nosecone
GRP Side Panels
2 x Carbon Fibre Rear Covers with Air Scoops
Carbon Fibre Bi-Plane Wing.
MSA Docs & a Box of Random Odds and Sods
The chassis is straight and is in very good nick from the roll-bar forward. It's taken a knock at some point in it's life on the front n/s corner, but the (minor) bronze-welded repairs are first class.
The rear of the chassis was converted by a previous owner for using a Yamaha R1 engine and a Quaiffe chain-drive diff (neither present!). There is a minor welding repair required to one of the 'shoulder' sections of the roll-bar.
The bodywork is structurally good, but will need a little TLC in a few areas. The CF rear panels and wing would have cost a small fortune to make and are in still in very good nick.
APRILIA RSVR ENGINE
V-Twin with Pseudo Slipper Clutch and Dry-Sump.
V990RR engine model (the top spec before the introduction of the V4). Only 65kg.
51mm TB's with Injectors, Velocity Stacks, TPS, Coil Packs.
Dry Sump Tank
The ECU and Clocks for the V990RR-engined bike are can-bus linked and few folk have done any hacking work on them. There is a well known conversion to run this second generation engine using the first generation ECU and clocks. It utilises the following parts which are also included:
First Generation ECU.
First Generation RSV Exhaust System (headers, link and single-sided silencer).
First Generation Wiring Loom with Switchgear (90% complete - some relays missing).
First Generation Stator, Flywheel, Pick-Up Sensor and Cover.
First Generation Fuel Pump.
I also have a complete and working set of First Generation instrument / speedo internals. The casing were damaged, but I had planned to integrate the clocks into the dash of my project anyway so that didn't matter.
All that's still required is to get a couple of First Generation rocker covers (£20 off of eBay), a little fettling to make them fit and then to put it all together.
PRICE
You know the score by now... you're paying less for the bits than I did!
I'll do the chassis, chassis components and bodywork / wing for £900 (a replacement wing would cost you the best part of £400 on it's own! ).
I'll do the engine and bits for £850. Yip, there are bare engines on eBay as low as £450-500, but by the time you've bought all the bits to make it go (which is pretty much what I'm offering), then you'll comfortably be over the 4-figure mark!
If you want the lot, then I'll make it £1600!
I'm be driving down to the Leicestershire area on Wednesday, so would include delivery if I was to meet up en-route, or if you were not too far away.
[Edited on 27/6/11 by scootz]
It's Evolution Baby!
welderman
posted on 27/6/11 at 02:51 PM Reply With Quote
good luck with the sale fella
Thank's, Joe
I don't stalk people
posted on 27/6/11 at 04:14 PM Reply With Quote
Cheers Joe!
mcerd1
posted on 27/6/11 at 04:46 PM Reply With Quote
so what engine are you using now ?
posted on 27/6/11 at 05:34 PM Reply With Quote
Keep up Robert!
It's a BMW HP2 Sport engine.
Steve Hignett
posted on 27/6/11 at 07:19 PM Reply With Quote
I would love to continue this project on, but as you know, losing my job and no hope of another one means toys have stopped completely for me!!!
Good luck with the sale!
mcerd1
posted on 27/6/11 at 07:27 PM Reply With Quote
Originally posted by scootz
Keep up Robert!
ok, I'm upto date now...
its blink and you miss it with your projects
posted on 27/6/11 at 07:33 PM Reply With Quote
To be fair, the trike project has been simmering away for the last few years... it's just the component parts that keep changing!
Not any more though!
lsdweb
posted on 27/6/11 at 08:11 PM Reply With Quote
- they did!
- and then some!
Guys - this is a really neat chassis and body combination and is a steal at that price!
Scootz - I'm more than happy to answer any questions about the original conversion and the car's history! I've also got a load of photos on the web and a couple of in car videos too if you want some links posting.
Wyn
posted on 27/6/11 at 08:20 PM Reply With Quote
Thanks very much Wyn!
Wheels244
posted on 27/6/11 at 09:18 PM Reply With Quote
U2U Sent
posted on 27/6/11 at 09:26 PM Reply With Quote
... and replied.
Wheels244
posted on 27/6/11 at 10:32 PM Reply With Quote
- they did!
- and then some!
Wyn
Hi Wyn
As you can see I'm interested in Scot's single seater.
I'll U2U you my email if you wouldnt mind supplying the info above.
Rob
lsdweb
posted on 28/6/11 at 07:25 AM Reply With Quote
Hi Rob
Emails sent!
Regards
Wyn
Guinness
posted on 28/6/11 at 08:10 AM Reply With Quote
Are you sure???
posted on 28/6/11 at 08:19 AM Reply With Quote
Are you sure???
YES!
Hi Rob
Emails sent!
Regards
Wyn
Thanks Wyn!
lsdweb
posted on 28/6/11 at 10:16 AM Reply With Quote
Pleasure - it's a cracking car and I would love to see it back running!
Some photos here -
https://picasaweb.google.com/tybrynbedw/Swift
https://picasaweb.google.com/tybrynbedw/Swift02#
And here are a few in car videos
http://www.kewego.co.uk/video/iLyROoaftQUz.html
http://www.kewego.co.uk/video/iLyROoaftKbj.html
http://www.kewego.co.uk/video/iLyROoafYbmn.html (they wouldn't let us film so I videod the data logging instead!)
Wyn
posted on 29/6/11 at 04:48 PM Reply With Quote
Please be aware that today I arranged for the small repair I mentioned to be done by Windle and also for then to tidy up some ugly welds. The chassis will therefore be in A1 shape. Unfortunately this has cost me £200-ish, but I want it to be absolutely right for it's new owner!
I will absorb 50% of this additional cost myself, but unfortunately I WILL HAVE TO RAISE THE CHASSIS PRICE FROM £900 TO £1k in order to recoup some the additional outlay.
*I would have just edited the original post, but the edit function date has expired*
posted on 29/6/11 at 04:53 PM Reply With Quote
That said, I will however honour the original price for Rob (only) who got his interest in early. Fairs fair!
spiderman
posted on 29/6/11 at 06:42 PM Reply With Quote
Hi
As others have said before "a picture is worth a thousand words" any chance of posting some on here?
Spider
posted on 30/6/11 at 12:56 PM Reply With Quote
Just a quick update to let folk know that I've given Rob (wheels) a couple of weeks to make a deal.
I'll update again once I know if it's definitely sold or now.
Cheers!
Yip... will get some on in the next few days.
lsdweb
posted on 30/6/11 at 12:59 PM Reply With Quote
Scot
I'm happy for you to post the link to my photos if you want!
Wyn
posted on 30/6/11 at 03:23 PM Reply With Quote
Thanks Wyn. I've got some snaps uploaded of the chassis, chassis components, and Aprilia engine bits.
I've still to add a pic of the engine, the bodywork and the rear wing. Will get them asap!
Archive Pic Linky
<<  1    2    3  >>
