hubby
posted on 30/6/11 at 09:17 AM |
Need more turning circle + suspension bottoms out
i got 2 questions for you experts as im thick as 2 planks and new to kit cars.
Q1 ive got a vindicator which i didn't build i believe it has sierra front suspension and steering the problem is it has a wide bonnet as its
capable of taking v8's with out a problem now that leaves me with a absolutly crappy turning circle half the time i have to drive it like im
driving a artic, having to take the corners wide otherwise im into the curb AS as its cault me out a few times. with full lock on the cycle wings hit
the bonnet/bonnet wheel arches so if i was to make the up new suspension arms say 25-50mm wider each side that should give me a wider front track and
there for more turning circle. what do i do with the steering rack as it would be 25-50mm shorter each side is there longer track rod ends or would
this make it unsafe etc YOUR ADVICE PLEASE
Q2 rear suspension is again sierra but i find it bottoms out (that's the suspension and not the car on the road)with a back breaking thump that
goes right through you and chassis and this happens with very little effort even when there's only me driving now could this be very tired
springs, tired shocks as when you driving normally it fine no wallowing or any thing of that nature. the car i would say sits where it should hight
wise
ashg
posted on 30/6/11 at 10:14 AM |
use these to extend the rack.
http://www.rallydesign.co.uk/product_info.php?cPath=1375_1594_1813&products_id=11843
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
hubby
posted on 30/6/11 at 10:21 AM |
cheers for that one ash, any idea about the suspension?
flibble
posted on 30/6/11 at 10:23 AM |
Any idea what poundage the rear springs are? Maybe need some stiffer ones.
posted on 30/6/11 at 10:25 AM |
a photo would help! It sounds like it doenst have enough travel up, or maybe the rideheight is a little low (i know you say it looks ok).
Ben_Copeland
posted on 30/6/11 at 10:31 AM |
Problem is, if you widen the front you'll have to widen the back. This could potentially cause you loads more issues/expense if your unlucky
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
blakep82
posted on 30/6/11 at 10:41 AM |
if its just the bonnet thats wider, a new bonnet would be an easier and less expensive change i'd say, although i don't know much about
vindicators, but if bodywork can be changed, i'd look at that first.
as said, changing the front track will mean you'll need to widen the back too, possibly new longer brake hoses, new wider rear wings, rack
extentions, wish bones, and shocks will probably need to be longer, so you'd need new ones too
as for the rack itself, it'l most likely have lock limiting rings inside, easily removed (they sit inside the gators)
________________________
posted on 30/6/11 at 11:13 AM |
Why? Nothing states front and rear must have equal track.
blakep82
posted on 30/6/11 at 11:22 AM |
yeah, thats true, but it will look a bit odd at a total of 100mm wider at the front i think. i would certainly want it looking equal all round. might
not be noticable. it was ben that said it anyway
hubby
posted on 30/6/11 at 09:50 PM |
not sure untill i measure it but i think the back is at least 50mm wider by looking at. i got the car in march with a new mot it had plastic stopper
in the rack so i took it out (about 25mm long) as it had to have them for the mot as the wheels were fouling the body. as it stands on full lock the
cycle wing and tyre hit the body and as the suspension goes up it hits the built in wheel arch of the bonnet and taken a notch out of it of about
15mm. the cycle wings are sitting as tight as possible in all directions to the tyre. as i didn't build it and its 15 years old now its a
guessing game as to what's on it. i suppose ill try some spring adjusters first and see if that helps first as i have them lying around the
garage.
any idea how i could find out the poundage of the springs?
any idea's on wheel spacers with longer studs as that seems to be an easier way off extending the wheels out as it got 18mm extenders on the
back wheels already. where would i get the extended studs and is it a bitch to get the old ones out?
thanks to every one for their inputs
RichardK
posted on 30/6/11 at 10:24 PM |
Could it be that the damping isnt happening and so its bouncing on the springs?
Rich
Gallery updated 11/01/2011
Bluemoon
posted on 30/6/11 at 10:34 PM |
If it's been put together correctly surely none of that should not happen?
I would guess the wheels hitting on full lock might be because of an incorrect wheel offset I would look here first to see what wheels it was designed
for. PPC had a table of offsets for different cars that might help...
Dan
hubby
posted on 1/7/11 at 06:16 AM |
Rich
that was one of the first things that i thought but if that was the case i would expect it to be all wallowing on the motorway doing 80mph but it
drives as you would expect it to ive been in tintops with knackerd shocks and its like being on a boat when the sea's a bit rough. with 2
adualts in it going over a speed hump at over 5mph the suspension bottoms out so when on a run in the lanes and you hit a dip in the road thats just a
little deeper than normal it bottoms out aswell. im just suprised that no one in the past has sorted it out
