Author: Subject: 7/16 pipe to master cylinder fitting
SteveWallace
posted on 17/7/11 at 03:19 PM Reply With Quote
I have a couple of standard girling master cylinders. Having lost one of my 7/16 UNF fittings I need a new one. These are the fittings that connect the low pressure side to the hose (push fit) that goes to the brake fluid reservoir. I assumed that these would be readily available from any motor factors, but having tried a couple, apparently, they are 'very specialist parts' and normal thread to push fit connectors are not that size.
I find this hard to believe, but thats what they said, so does anyone know where I can get one from?
Toltec
posted on 17/7/11 at 03:28 PM Reply With Quote
Saw this while deciding what master cylinders to get last week-
http://www.compbrake.co.uk/Brakes-Acc-39-s/Unions/Master-cylinder-union-7/16-to-push-fitting/prod_1018.html
Ben_Copeland
posted on 17/7/11 at 03:38 PM Reply With Quote
Rally Design also do them....
Ben
Locost Map on Google Maps
Enter Your Details Here
