Author: Subject: Honda Civic 2003 Drive belt question. 1.6
cadebytiger
posted on 25/7/11 at 02:02 PM Reply With Quote
Hello All
Does anyone know the recommended number of mile/age you should change the drive belt on a honda civic 2003 1.6
Thanks again!
[Edited on 25/7/11 by cadebytiger]
daviep
posted on 25/7/11 at 02:34 PM Reply With Quote
If your are asking about the cam belt (timing belt) then 75,000miles or 8 years according to Autodata.
Davie
posted on 25/7/11 at 02:43 PM Reply With Quote
As above istr it is now a minimum requirement for anything imported to the USA.
I can also say based on experience Honda belts have been almost never known to break.
cadebytiger
posted on 25/7/11 at 03:15 PM Reply With Quote
yes cam belt
Brilliant - thanks
Bare
posted on 25/7/11 at 04:11 PM Reply With Quote
Water pump usually needs replacing at same time as one is doing the Belt.
It's just easier to do both together rather than separately.
Yes the belts DO break.. but usually at much higher than 80k miles.
Having said that 1.6 engines/ parts are dirt cheap to buy used :-).
