Front Row Joe
| posted on 4/8/11 at 12:12 PM |
What about this for a filter??
Pre pump low presure filter for those of us with 15mm id pipe. It has a 400 micron?? stainless mesh inside. What do you reckon??
http://www.toolstation.com/shop/Plumbing/Compression/Compression+Inline+Y+Filter+15mm/d20/sd2697/p52821
[img]http://www.toolstation.com/images/library/stock/webbig/52821.jpg?rand=381886896[/img]
[Edited on 4/8/11 by Front Row Joe]
Myke 2463
| posted on 4/8/11 at 02:54 PM |
That's a different idea and locost, i think i would rather have one with hose tails, inline Y filter 1/2" £3.30 + hose tails. Cat 40 page
291.
Be Lucky Mike.
Litemoth
| posted on 4/8/11 at 03:37 PM |
...Bit of a heavy old clanker though don't ya think?.....
Are we talking central heating or for the car?
15mm id hose?? ...wow, that's massive.
There's all sorts of blinged-up versions out there....admittedly 15mm won't be an option. They're all around 3-6 quid ish
[Edited on 4/8/11 by Litemoth]
ss1turbo
| posted on 4/8/11 at 07:25 PM |
400 micron will stop small birds and children...but not much else!
I've been looking for something locost as an inlet filter with 12mm or 1/2" tails and so far the best is about £9 each +£9 delivery (spec
is apparently a crop sprayer with a 6.7litre Cummins diesel - so should be fine..). Unless anyone finds anything better, anyone up for a little group
buy?
Long live RWD...
Litemoth
| posted on 4/8/11 at 07:43 PM |
What about this:
12mm inline pre pump fuel filter sytec walbro | eBay
Or this:
LINKY
Or these:
LINKY
ss1turbo
| posted on 4/8/11 at 08:41 PM |
quote: Originally posted by Litemoth
What about this:
For some reason they hadn't popped up in my searches - maybe they weren't on there a week ago? Anyway - that'll do me nicely..
[Edited on 4/8/11 by ss1turbo]
Long live RWD...
Front Row Joe
| posted on 4/8/11 at 08:59 PM |
My pump inlet is 15mm Id so I'm having to use plumbing parts as they seem to be the only 15mm available. Especially as I need a reducer to get
it down to 8mm for the tank. 400 microns is a bit big then? I was just looking for something that didn't restrict the flow to the tank too much.
Litemoth
| posted on 4/8/11 at 09:43 PM |
What fitting is on the pump inlet ....? 15mm ID seems really big. Put a pic up...I'm sure we can work something out that's more
standard
Only you and the Emma Mærsk are using 15mm
AdrianH
| posted on 4/8/11 at 11:07 PM |
I'd like to see the kit car chassis to take that little engine.
Adrian
Why do I have to make the tools to finish the job? More time then money.
blakep82
| posted on 4/8/11 at 11:17 PM |
awesome, an engine with its own observation deck!
what pump is it? i'm surpised of anything car related having 15mm inlets.
________________________
Front Row Joe
| posted on 5/8/11 at 01:15 AM |
Its a Bosch pump. Believe its from a cosworth. definitely 15mm as I measured it up with some calipers. I've come across threads with others who
have had the same problem. The only solution I have found is plumbers pipe. There must be a tidier solution?
atomic
| posted on 5/8/11 at 11:51 AM |
Well if it is a Bosch and indeed for a Cosworth then it should be either a Bosch 040 or 044. They are in the region of 300LPH and will require a
100micron pre pump filter and ideally you should also use a 40micron post filter
