New Topic New Reply
Author: Subject: Adjustable sierra steering column
thenorthface
posted on 9/8/11 at 07:49 PM Reply With Quote
Hu Can u use a sierra adjustable steering column on a Mk Indy without modifying any brackets etc ?
snapper
posted on 9/8/11 at 08:01 PM Reply With Quote
Yes
I eat to survive
I drink to forget
adithorp
posted on 9/8/11 at 08:49 PM Reply With Quote
Are you using a paddle shift? If so and it's a rod operated one you'll need to lock out the adjustabe length (height is OK). If it's a cable shift then the outer cable achorage has to be on the column or the same applies.
http://jpsc.org.uk/forum/
thenorthface
posted on 9/8/11 at 08:54 PM Reply With Quote
cheers for that am going to be using a paddle shift with rods so i will lock out the adjustablity once am happy with the setting
New Topic New Reply
