New Topic New Reply
Author: Subject: Xbox 360 repair or bin?
steve m
posted on 15/8/11 at 10:08 AM Reply With Quote
Grandsons Xbox 360 is not working and shows 3 red rings
Can these be fixed, or binned and get a new one
regards
[Edited on 15/8/11 by steve m]
balidey
posted on 15/8/11 at 10:18 AM Reply With Quote
Check manufacturing date, it could still be valid for a microsoft repair for free.
Failing that, yes they are repairable either DIY or send off.
Don't bin it.
Dutch bears have terrible skin due to their clogged paws
pekwah1
posted on 15/8/11 at 10:20 AM Reply With Quote
sent mine off to xbox, service was really quick!
just give them a ring and give the serial number and they'll tell you if it's in warranty.
hughpinder
posted on 15/8/11 at 10:21 AM Reply With Quote
have a look at
http://www.avsforum.com/avs-vb/showthread.php?t=717200
to try and isolate the problem, then look at
www.ifixit.com which will show you how easy or difficult it may be to fix.
Regards
Hugh
RichardK
posted on 15/8/11 at 10:22 AM Reply With Quote
I believe they will fix the red ring issue even if out of warranty, but only if the case hasn't been opened.
Rich
Gallery updated 11/01/2011
Irony
posted on 15/8/11 at 10:28 AM Reply With Quote
Check with microsoft first
I have had two xbox's go with this problem and I have fixed them both with a kit bought from ebay (about 3 quid). It's something to do with the way the heatsinks are fitted to the processors (assuming this is the problem you have, it might not be but I doubt it). However each fix gave me about 6 months extra play time and then they went again. After muching repairing I just traded in my games and controllers and managed to get a Xbox elite for £50 quid at games station. Apparently the younger the xbox the less chance it'll have this problem.
My advice would be to have ago at the heatsink repair option as its cheap but remember your on borrowed time until it happens again. This is my experience of xbox's but some people report after the heatsink repair everything is fine.
mistergrumpy
posted on 15/8/11 at 10:51 AM Reply With Quote
Mine was repaired out of warranty by Microsoft and in double quick time, without hassle and returned with Microsoft points card as well.
MikeFellows
posted on 15/8/11 at 11:04 AM Reply With Quote
does it turn on at all?
for 15 mins maybe?
Mike
steve m
posted on 15/8/11 at 11:26 AM Reply With Quote
No it does not seem to work at all, just 3 rings!
Jimbob
posted on 15/8/11 at 11:48 AM Reply With Quote
Same here, really good service
Proby
posted on 15/8/11 at 12:19 PM Reply With Quote
It Can be repaired no problem. Try Microsoft for warranty, I have fixed a couple, while the repair kits on eBay using washers/screws for the 2 heatsinks do work, that is not the best solution, as the fault will come back to haunt you (and cause damage to the CPU & GPU mounting pins). The best solution is to remove the main board and find someone who will reflow the board for you (using an IR reflow oven not a crude heatgun method!) This melts and reflows the solder on the delicate pins on the underside of the processors. The one I did with a repair kit lasted 4 months, the others I had the boards reflowed have been done 18 months+ and still going strong.
[Edited on 15/8/11 by Proby]
jossey
posted on 15/8/11 at 02:14 PM Reply With Quote
it can be repaired free if upto 5 year old. Unless its been openned or MOD'ed.
If its older just bin it. i have had 2 RROD and fixed both. one lasted 2 days other lasted 3 months. either way not worth the fix.
DJ
David Johnson
Ninehigh
posted on 16/8/11 at 05:45 PM Reply With Quote
Bin it and get a PS3
New Topic New Reply
