Author: Subject: Type 9 to Cortina Speedo
chrisbeale
posted on 18/8/11 at 07:53 PM Reply With Quote
Am Upgrading (actually downgrading i suppose) from a digi dash back to classic clocks in the 7. i have been offered by a friend a set of Cortina 1600GT Mk2 (smiths 0-100mph) gauges to fit. i know im going to need a right angle adaptor and a nice long speedo cable but does any one know how accurate this will be? I know the Cortina didnt use a Type 9 and i guess my wheels are a little smaller, dont really want to be messing around with all the output drive gear sizing etc if its going to be quite close anyway.
Also if anyones got a right angle drive lying around they want to sell???
Any help as always much appreciated
RichardK
posted on 18/8/11 at 08:00 PM Reply With Quote
I managed to get away with a normal speedo cable by making a little cover, was still tight but works well, no needle flutter.
Just thought I'd mention it
Rich
Gallery updated 11/01/2011
chrisbeale
posted on 18/8/11 at 08:04 PM Reply With Quote
That looks good, I'm quite handy with the ali so its a good option. What gauge to you run?
snapper
posted on 19/8/11 at 06:27 AM Reply With Quote
Cortina's ran mainly 13" wheels with 165 80 profile
The diffs were usual 3.7, the only way to change the output to the speedo was by different output drive gears, little plastic gear wheels.
Therefore unless you find all the different output gears available and work out what suits your set up the only other way is to have the speedo calibrated.
I eat to survive
I drink to forget
RichardK
posted on 22/8/11 at 07:08 AM Reply With Quote
Original square Sierra clock put into a knackered round speedo casing.
Rich
Macbeast
posted on 22/8/11 at 08:32 AM Reply With Quote
Speedy Cables will recalibrate your speedo, given figures like wheel circumference, number of rotations of drive cable per 6 wheel revs etc. They also make up drive cables to match boxes to speedo heads.
http://www.speedycables.com/calibration.html
[Edited on 22/8/11 by Macbeast]
paulf
posted on 22/8/11 at 08:46 PM Reply With Quote
I used a type 9 of unknown origin but most likely a Sierra and found that with a 1000 rev per mile speedo which seems a common version either ford or smiths a 3.89 diff and 185/70/13 tyres the speedo was accurate to within a couple of mph right through the range, I now have 60 profile tyres and it over reads by about 5mph at 80mph.So depending on your tyres and diff it may not be far out. I ran the speedo cable through the tunnel wall and across the drivers floor just in front of seat and then up the chassis to the back of the dash, i used a shortened Sierra cable .
Paul
