Author: Subject: Sump
lewis635
posted on 1/8/04 at 09:29 AM Reply With Quote
Sump
Does anyone know if a 2 wheel drive saphire cosworth sump will fit onto a 2.0 pinto. somebody said to me that they are the same 205 block is this right.
subk2002
posted on 1/8/04 at 10:02 AM Reply With Quote
rs alloy sump fits im not sure if the saphire one is the same i think so.
NS Dev
posted on 1/8/04 at 09:31 PM Reply With Quote
never done it but the block is certainly the same, not sure on the oil pump (pickup pipe is attached to it) but I would guess it is also the same?
lewis635
posted on 2/8/04 at 05:12 AM Reply With Quote
Thanks guys
cosworth
posted on 2/8/04 at 06:21 AM Reply With Quote
yes it will fit
locoboy
posted on 2/8/04 at 10:54 AM Reply With Quote
sorry for the hijack
What thickness plate have people used to reconstruct the sump when chopping the 2.0 pinto one?
Locoboy
James
posted on 2/8/04 at 11:19 AM Reply With Quote
90% sure I went with 18 gauge. Don't think I went as thick as 16.
HTH,
James
locoboy
posted on 2/8/04 at 11:22 AM Reply With Quote
is that about 1.6mm ish?
Locoboy
James
posted on 2/8/04 at 11:28 AM Reply With Quote
16 gauge is 1.6mm
18 gauge is 1.2mm
I just went with a thickness similar to what was there already so as to make it easy to weld.
Atb,
James
