Author: Subject: Sierra master cylinder rod ?
thenorthface
posted on 14/9/11 at 11:08 AM Reply With Quote
Just got my sierra master cylinder off eBay but there is no thread inside to attach some stud bar for the brake pedal ? How do u attach the brake pedal to them ?
Ben_Copeland
posted on 14/9/11 at 11:46 AM Reply With Quote
Did it not come with a push rod attached? Sounds a bit suspicious. Has it got any internal parts inside it???
It might be the plunger is just pushed in. Remove the rubber and check.
Ben
Locost Map on Google Maps
Enter Your Details Here
ReMan
posted on 14/9/11 at 12:23 PM Reply With Quote
If you meean inside the piston, there is no thread, just an empty hole with a rounded bottom
The rod end just rests in there. The held end is with a clevis onto your brake pedal
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Bluemoon
posted on 14/9/11 at 12:36 PM Reply With Quote
Ditto, made my own push rod from HT M8 bolt, rounded off end in bench grinder..
thenorthface
posted on 14/9/11 at 01:36 PM Reply With Quote
Is the m8 bolt ok to rattle around in the tube ?
lotusmadandy
posted on 14/9/11 at 01:59 PM Reply With Quote
I also made mine from an M8 HT bolt and a clevis that mounts to
the break pedal.It wont rattle around if you adjust all of
the free play out.
thenorthface
posted on 14/9/11 at 02:42 PM Reply With Quote
Cheers for that , where did u get the Clevis from ?
