Author: Subject: Pinto inlet Manifold gasket
Autosri
posted on 5/10/11 at 11:50 AM Reply With Quote
Hi guys I'm looking to replace the intake manifold gasket on my pinto 2l it has a proper manifold to fit twin 40 dcoe webers on where could I get a gasket or is it likely to be an original ford gasket
melly-g
posted on 5/10/11 at 12:09 PM Reply With Quote
I replaced mine 2 weeks ago! It's easy to get just the gasket from almost any motor factors.
Got mine from exhausts unlimited only £3 !!
JeffHs
posted on 5/10/11 at 12:25 PM Reply With Quote
But check that the gasket doesn't partially mask the bores in the head. Mine from a local factor needed trimming to suit
Autosri
posted on 5/10/11 at 12:46 PM Reply With Quote
So I should just ask for a standard ford gasket and that will fit a twin dcoe manifold
omega0684
posted on 5/10/11 at 04:50 PM Reply With Quote
walk in and say "one pinto inlet manifold gasket please" shouldn't cost you more than a couple of quid
here you go - Ebay Link
[Edited on 5/10/11 by omega0684]
Autosri
posted on 5/10/11 at 07:09 PM Reply With Quote
Thanks for the help guys got one on it's way to me for the weekend so will get it swapped out
