45mm Jenvey Throttle bodies
I'm selling my Jenvey Bodies
Below is what I'm selling.
45mm Jenvey throttle bodies complete with fuel rail, TPS and Linkage.
70mm Trumpets
Adjustable fuel reg with gauge
Loking for £600 delivered for these.
Below is the original add as these are currently fitted to my 205 MI 16 so if someone want the lot fire away.
I'm selling my jenvey bodies and inlet manifold.
The inlet is split new. Below is what I'm selling.
70mm Trumpets
GTI 6 Injectors
Colin Satchell Inlet Manifold (This is longer and gives a better angle than what jenvey/Longman have to offer) This manifold also connects the bodies
upside down so gives a better inlet tract.
Also with the above set up you have the option to run 8 injectors. I run the injectors in the original position and have blanked the injector holes in
the bodies.
The inlet manifold will come complete with fuel rail and regulator and GTI 6 injectors, I will also supply the fuel rail for the Jenvey bodies. The
bodies have been balanced and throttle pot set up so if you have an ECU these are good to bolt on and go.
These are mounted to my MI 16 in my 205, The total inlet length is 400mm from trumpet face to valve face.
I'll do the lot including delivery for £700
