Author: Subject: Fuel pump pre-filter
GregMcN
posted on 21/10/11 at 08:06 PM Reply With Quote
Hi
Has anyone come across a cheap fuel pump (injection not carb) pre-filter with 11 or 12mm fittings. They all seem to be 6 - 8mm only and I am reluctant to spend alots when the pump was only £50.
Thanks Greg
big-vee-twin
posted on 21/10/11 at 10:42 PM Reply With Quote
I used this type made by Sytec/FSE you can fit different pipe fittings I have an 8mm inlet and 10mm outlet
You will find them on ebay for less than a tenner
[img] Fuel pump position
Fuel pump position
[/img]
[Edited on 21/10/11 by big-vee-twin]
http://www.triangleltd.com
