Author: Subject: Plate compactor for a new lawn?
tegwin
posted on 31/10/11 at 04:32 PM Reply With Quote
Anyone know much about grass?!
Have been putting this one off for weeks, but its about time I get the seed down before it gets too cold!
I turned over all the soil to a depth of around a foot... then added 4" of topsoil ontop of the lot...
Let it settle for around a month now but I find its still quite spongey.
Before I put the seed in, I am thinking it might be wise to hire a vibrating plate compactor and whack it all down to make it less "springy"... fill in any recesses and then rake the surface to take the seed...
Does this sound like a bad idea? Will a vibrating plate just sink into the mud and be lost?!
www.verticalhorizonsmedia.tv
posted on 31/10/11 at 04:52 PM Reply With Quote
The usual trick is to get a few mates round and do a "Zorba the Greek" walk across the ground - side-by-side, shuffling along in very short steps (one footprint just in front of the previous one) and putting your weight on your heels. The idea is to compress it down a bit,but not squash it completely. You'll have to rake it flat again afterwards.
I think a vibrating plate would be OTT.
BTW: you're getting a bit late for grass seed! That's usually a September job, maybe early October, not heading into November!
[Edited on 31/10/11 by David Jenkins]
tegwin
posted on 31/10/11 at 04:54 PM Reply With Quote
Yeah I know im a bit late... But I am down in the South... its almost tropical here ALL THE TIME If I get it in this week I think I should be ok.
Benzine
posted on 31/10/11 at 04:58 PM Reply With Quote
does it have to be grass?
mark chandler
posted on 31/10/11 at 04:59 PM Reply With Quote
I know your pain, its as David says, shuffle walk to pack it down then rack in some seed and roll if possible....
posted on 31/10/11 at 05:16 PM Reply With Quote
You just need some friends round to help....
Or, go the whole hog
posted on 31/10/11 at 05:37 PM Reply With Quote
You want a gritty sandy base for grass carefully graded and not too compacted, just stamping it down by walking on a plank is usually enough, the grass roots will soon lock it into a solid surface.
Sowing grass at this time of year is 2 months too late, it just won't sprout.
[Edited on 31/10/11 by britishtrident]
Dingz
posted on 31/10/11 at 06:05 PM Reply With Quote
My son out law seeded a lawn after a lot of pushing! 3 1/2 weeks ago it is coming up at the moment but I thought that was too late. We have been lucky that the weather has been so mild. That was just walked over after preparing .
went on and on.
Litemoth
posted on 31/10/11 at 07:19 PM Reply With Quote
A roller (and not a tarmac compacting one!!), a rake and a straight edge are recommended by those in the know.....the roller will show up the low spots....rake the high spots into the low spots.......level with a straight edge ...and repeat. .....or do the shuffle as suggested above.
Spongey is good...young grass hates hard-compacted soil...don't Whacker for gawd sake
[Edited on 31/10/11 by Litemoth]
