Author: Subject: Plumbing/Heating question
locosaki
posted on 31/10/11 at 08:33 PM Reply With Quote
The condensate from a boiler, Is this considered part of the flue ?
If so, Should a tundish be used inside the house as an airbreak ?
I would have thought the condensate is part of the flue therefore the condensate discharge pipe should be sealed into the drain or to the outside !!
Wadders
posted on 31/10/11 at 08:50 PM Reply With Quote
Most condensing boilers have an internal condensate trap, so as long as its full of water, no fumes will pass.
Worcester now advise the fitting of a tundish in case the external pipe freezes, to save the boiler filling with water.
They obviously don't care about the ensuing flood
Al.
