theconrodkid
posted on 5/1/12 at 08:57 AM |
garage roofing
a part of my garage roof has gone awol,it,s the cement type corrogated stuff,i cant seem to find it on line anymore,any ideas,anyone want a job
who cares who wins
pass the pork pies
chrisbeale
posted on 5/1/12 at 09:05 AM |
Are you sure its cement and no corrugated asbestos? You won't find asbestos for sale any more.
jossey
posted on 5/1/12 at 09:10 AM |
the corragated stuff is normally asbestos which you shouldnt be using anyway as when it cracks it gives off fibres.
Double check if its corragated then replace it with MDF and Bitumen backed roofing felt. it costs about £25 a roll and my last garage 6m x 4m used 5
rolls.
if your pulling the rest of the roof down do it when its wet as it keeps the dust settled.
If its not asbestos then im happy as you can just replace the bit you need with corragated bitumen sheets...
David Johnson
splitrivet
posted on 5/1/12 at 10:10 AM |
About to fix mine when this cr@p weather subsides. I was going to leave the original corrugated stuff in place then batten over the top with cls
timber, insulate then fix with metal cladding was hoping that double skinning it as it were would make it a bit warmer.
Costing all in with PVC coated sheeting from a local guy, the cls and insulation comes to about £500 which I thought wasnt too bad the garage is a
long double.
Cant you claim on the insurance though if its been caused by the recent weather.
Bob
adithorp
posted on 5/1/12 at 10:28 AM |
I re-did a garage roof this summer and used corrugated bitumen sheets (from Wicks) to replace the old (probably) asbestos ones. Very easy to use,
though the sheets linked together and formed just the right size for my roof without any cutting required.
http://jpsc.org.uk/forum/
posted on 5/1/12 at 11:22 AM |
The asbestos cement corrugated sheets are a pain to get rid of as well. My local tip will only take a small amount and you have to fill in a load of
paperwork even then.
designer
posted on 5/1/12 at 11:43 AM |
Aren't you covered by house insurance/
If so you will get a new roof.
YQUSTA
posted on 5/1/12 at 11:46 AM |
I have 10x20 ft of the corrugated stuff round the back of my house from when I took down the garage.
You can take it all if you want it.
"If in doubt flat out"
Colin McRae
posted on 5/1/12 at 11:52 AM |
I used the stuff from Wickes as well, it's been up 12 years and no problem though it has gone a nice shade of green.
mcerd1
posted on 5/1/12 at 12:10 PM |
steadmans supply a couple of different types of non-asbestos stuff
you can download the data sheets to see if its the same sizes as your existing stuff:
http://www.steadmans.co.uk/products-fibrecement-sheet-roofing-cladding.asp
[Edited on 5/1/2012 by mcerd1]
robocog
posted on 5/1/12 at 12:48 PM |
I have several sheets of the (possibly asbestos) sheets here from my garage that is yet to go up
A couple were cracked so now debating whether to just do the MDF/sheet ply and bitumen thing instead
If you take all my sheets of roofing away it will simplify my decision and would be helping me out big time
Not sure they will fit into a car though...will measure sheet dims
Laters
Rob
theconrodkid
posted on 5/1/12 at 09:03 PM |
my ever helpfull Polish neighbour (not the wa**ers the other side) has offered to make a temp repair on sat and a new ply/felt one in the summer
cheers for your imput peeps.
BTW,the garage is about 10 years old so could the roof be asbestos?
who cares who wins
pass the pork pies
theconrodkid
posted on 8/1/12 at 11:15 AM |
went to wickes and b n q,neither have what i want,only clear weak plastic or the green floppy stuff
looks like a ply and felt jobbie in the summer
who cares who wins
pass the pork pies
Volvorsport
posted on 8/1/12 at 12:05 PM |
or a fibreglass one.........
www.dbsmotorsport.co.uk
getting dirty under a bus
theconrodkid
posted on 8/1/12 at 12:15 PM |
been looking at steel sheet ones with anti condensation coating,looks cheap and easy enough and i can weld on brackets for the lights before i put
them up
are fiberglass ones strong enough?,it,s a bit windy on the corner hence why my roof went awol for the 2nd time.
also where can you get them,i,m looking at flea bay at the mo
who cares who wins
pass the pork pies
