DRCorsa
posted on 7/1/12 at 10:06 AM |
Sierra (bolt-on) driveshafts positioning
Yesterday i concluded the refurbishment of my Sierra driveshafts and CV joints.
A good clean and powdercoating and they look as new.
The problem is that when i bought my Sierra diff and driveshafts, thise were dissasembled, i mean the diff had not the driveshafts bolted on but
seperate.
As you can see in the pics below, one face of the shaft has a "star" stamped on it while the other has a number of circular marks. The
question is which face goes to diff side and which goes to hub side? i remember reading in a thread here that if you install them the wrong way
around, they tend to break!
I have ordered a Sierra Haynes manual but if you could help me until it arrives, it goes well.
Any help greatly appreciated! Thanks!
[Edited on 7/1/12 by DRCorsa]
AdrianH
posted on 7/1/12 at 11:22 AM |
My Sierra manual does not mention any differences, star, or circles and any special way to fit the bolt ons, so good luck with the down loads They may
be more relevant then the basic manual.
Adrian
[Edited on 7-1-12 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
DRCorsa
posted on 7/1/12 at 11:25 AM |
The last manual was complete but no mentioning on the symbols sadly..
RichardK
posted on 7/1/12 at 01:05 PM |
I personally wouldnt worry, cant see it making any difference, all parts are machined the same...
Gallery updated 11/01/2011
MikeCapon
posted on 7/1/12 at 01:20 PM |
To the best of my knowledge a stressed component will survive longest if the stresses are not reversed. I'm guessing here, but I reckon the
marks are there so you can put the shafts back in the same orientation as when dismantled.
As you clearly do not have this information available I'd just put them both back the same way. It is pretty much splitting hairs anyway as the
stress on a drive shaft is reversed on the overrun although maybe not to the same extent as a clutch dumped, wheel spinning getaway.
Unless of course your gearbox and clutch control is as bad as a bad thing...
Mike
DRCorsa
posted on 7/1/12 at 01:25 PM |
I hope this is the case but the fact that the manufacturer has used these symbols there, means that installing them the right way is crucial.
Driveshafts are getting some torsional tension. If you fit them the other way around, the tension will be at the opposite direction. Maybe this is the
reason why some people say that driveshafts will probably break if you fit them wrongly.
I know it's a quite unsual question for someone to know the answer, but maybe any member here happens removing the driveshafts (for cleaning,
boots changing etc) and could take a look at the symbol each side?
RichardK
posted on 7/1/12 at 01:31 PM |
The reason I'm suggesting it doesnt matter is that in the genuine ford workshop manual for the sierra cosworth it doesnt mention it at all in
either the dis assembly section or reassembly so I'm working on the basis if it was critical it would be mentioned somewhere.
I would understand it if the haynes manual missed something like that out but not the pukka workshop manual that ford dealers used back in the day.
However would be useful to know if somebody had documented it.
Hope you get it sorted.
Rich
DRCorsa
posted on 7/1/12 at 01:33 PM |
Thanks a lot for all your help Rich!
MikeCapon
posted on 7/1/12 at 01:37 PM |
I think the reason it's not mentioned Richard, is that it was probably taken as read. In the same way you'd put an exhaust valve back in
the port it came out of rather than mixing them up.
I still reckon it's splitting hairs though given the torque reversal on a drive shaft. May be on a race car running slicks and 500 bhp it could
eventually become an issue. What shafts did the Cossie run anyway? Standard or otherwise....
Chippy
posted on 7/1/12 at 03:44 PM |
Funny thing just taken mine off, and in both cases the star end was towards the wheel end, now as to whether that is correct I have no idea, but in
10K miles, (and some pretty hectic starts), I havn't broken one yet, so maybe that is correct, OR, it doesn't matter, Cheers Ray
DRCorsa
posted on 7/1/12 at 04:25 PM |
Wow, that helped me quite a lot!
THANKS!!!
RichardK
posted on 8/1/12 at 01:21 AM |
Dont you just love this place
DRCorsa
posted on 8/1/12 at 02:04 PM |
Absolutely!
