Author: Subject: Inverter MIG welder
tegwin
posted on 7/1/12 at 10:57 PM Reply With Quote
Inverter MIG welder
I think it is time to get a "proper" MIG welder. The little hobby one I have is simply not up to the job
I had toyed with the idea of a TIG welder but the cost for a decent one is a bit ouch... plus I think a MIG is more versatile.
The question is, are the inverter MIG welders that claim they can weld mild, stainless and alloy(with suitable gun) actually any good?! Will I be able to do decent looking welds on stainless for example?
I very much like the look of the R-Tech inverter Migs (the top two on this page) HERE. A little more than I wanted to pay, but they look pretty good...
Can anyone suggest any similar MIG machines that might be a better price? Its worth paying for something that will last quite a few years, but as I am tight fisted...... the less the better really.
www.verticalhorizonsmedia.tv
daviep
posted on 7/1/12 at 11:38 PM Reply With Quote
All MIG's can weld stainless and aluminium, you need argon and a teflon liner for aluminium and they're not much use for thin stuff.
Personally I wouldn't be bothered for anything too hi tech in a mig, your mig isn't going to be a portable machine with a 15kg spool of wire and 50kg of gas cylinder strapped to it so why the need for inverter drives when a transformer will work as well or better and be 100% reliable.
You really want a machine which will take 15kg spools as they are about half the price of 5kg spools kg for kg.
Just my opinion.
Davie
907
posted on 8/1/12 at 02:01 AM Reply With Quote
Hi.
If I can (afford it) I like to buy well known industrial makes of equipment.
If my 1996 Lincoln 210 MIG gave up on me, and I've no reason to think it will,
I would think very hard about this ESAB.
If you are after, (quote) a "proper" MIG welder, (unquote) then price wise this falls
between the two in your link.
http://www.wellyweld.com/products/esab-origo-mag-c201-43441.aspx
HTH
Paul G
Edit to add:-
If I have anything heavy to weld I borrow my mates C3000i.
An excellent 3ph machine, but should possibly be called the C £3000 i
[Edited on 8/1/12 by 907]
tomgregory2000
posted on 8/1/12 at 08:09 AM Reply With Quote
i have an r-tec 160amp portable inverter mig welder, it produces fantastic welds.
the last time i did some welding was back at college about 8-9 years ago and then i git this unit and after about 10 mins of practice i was ready to start welding up my land rover chassis and was doing lovely welds, my old man had a go with it, he works at a welding and fab place and he loves it and one of my mates is a fully qualified welder and he keeps trying to steal it from me because he likes it so much.
the best thing with the inverter mig is that they are soooooo much lighter than the traditional mig.
One bad point is that the unit wont like to get wet so no using outside in the rain
but the inverter welder can be run off an extension lead or a generator and they have a very high duty cycle
I have to say i like mine alot
tomgregory2000
posted on 8/1/12 at 08:12 AM Reply With Quote
Here is a pic of some of the welding
this is after a couple of hours of welding
thought i would add a couple more
[Edited on 8/1/12 by tomgregory2000]
posted on 8/1/12 at 09:57 AM Reply With Quote
I have a Kemppi Minarc like the link and it takes a 5kg spool and is very portable. It welds flawlessly even using pub co2 on thin metal. It's not a cheap option but it is good.
T66
posted on 8/1/12 at 10:56 AM Reply With Quote
I picked up a used Clarke 195 mig - so not really a workshop mig but a reasonable home use mig - will do anything, produces good welds, uses big spools
cost £275
Parts backup via machine mart.
ssc28
posted on 8/1/12 at 01:22 PM Reply With Quote
I have used a migatronic machine for the last 12 years and sadly it has recently given up. I cant fault the thing as it has had some serious use and abuse. I'm now looking to replace it and want a decent spec machine. These seem to have all the things I need and are of a good quality for the price.
sorry dont know how to do a link
http://www.weldequip.com/portamig-mig-welders.htm
