Author: Subject: Megajolt TPS Help
sssline
posted on 12/1/12 at 07:50 PM Reply With Quote
Megajolt TPS Help
I am converting a MAP ecu to TPS and believe the list below is what I need, from autosportlabs, I've looked on RS and can find lots of components that are listed for each of these just not sure which to choose.
Just wondered if there was an RS, Farnel etc part number list to pin them down anywhere??
Tony.R
R3 1K ohm 1/4W 5% tolerance resistor. Markings: brown-black-red-gold
C11 0.1uF ceramic capacitor
C12 0.001uF ceramic capacitor
C13 0.22uF ceramic capacitor
C14 4.7uF Tantalum Capacitor. This capacitor is polarized! Match the "+" marking on the body of the capacitor with the "+" on the circuit board's silkscreen.
D7 1N4733 5V Zener Diode. Be careful installing this device since you will likely have the glass version, and it's a bit fragile. Bend the leads accurately so the device slides into the board and mounts flush to the surface. Note band orientation!</td>
L1 1uH Ferrite core inductor
Autosri
posted on 13/1/12 at 12:38 AM Reply With Quote
Do you have a maplins local to you that way just print off the list you posted above and the guys will normally help you
