Author: Subject: sierra diff info
ajw
posted on 20/1/12 at 09:57 PM Reply With Quote
sierra diff info
I have a sierra viscous 3.9 diff with bolt on lobro shaft. Need to find out what ford had a bolt on diff with no viscous unit as
Tranx tell me the lsd they are supplying to me will not fit viscous case.
Question; which ford had 7" bolt on non viscous diff ratio not important as fitting 4.4--1
HELP
mookaloid
posted on 20/1/12 at 10:04 PM Reply With Quote
you are looking for a disc braked rear so probably a 2.0 ghia or a higher spec model
Chippy
posted on 20/1/12 at 11:07 PM Reply With Quote
Find that a bit strange, because as far as I am aware all the 7" diff casings are the same, LSD or not. May be wrong, have been in the past, Cheers Ray
CNHSS1
posted on 21/1/12 at 07:11 PM Reply With Quote
Its not the case, its the output shafts that the CVs bolt to. Trans needs non Led output shafts
ajw
posted on 21/1/12 at 10:10 PM Reply With Quote
Thanks guys, the sales people at tranx indicated the issue. If its the bolt on portion of diff what sierra has disc brakes with no lsd
