Author: Subject: Split convoluted sleeve
Michael
posted on 23/1/12 at 09:54 PM Reply With Quote
Where on the highstreet can you get split convoluted sleeving?
I only need a short lengh as have added a high level stop light and that is the last i need.
I can only find online sellers.
PSpirine
posted on 23/1/12 at 10:20 PM Reply With Quote
Halfords or other Car Audio place? Used in installs sometimes and is actually included in a lot of wiring kits..
Michael
posted on 23/1/12 at 10:30 PM Reply With Quote
Have tried Halfords, but will look around some more
PSpirine
posted on 23/1/12 at 10:31 PM Reply With Quote
Alternatively... how much are you after and what thickness? I'll check whether I've got any lying around
Michael
posted on 23/1/12 at 10:33 PM Reply With Quote
6mm inside diameter and about half a meter in lengh.
The annoying bit is I have about 8" of the stuff but not enough for what I want.
Then I have quite a bit left of the other sizes that I have used.
[Edited on 23/1/12 by Michael]
craig1410
posted on 23/1/12 at 10:41 PM Reply With Quote
If you're stuck, VWP will sell you a metre for 63p here:
http://www.vehicle-wiring-products.eu/VWP-onlinestore/sleeving/sleeving.php
Unfortunately postage is £3.95 an VAT an additional 0.92 so £5.50 in total...
I'll have a rummage in the garage tomorrow night unless someone else beats me to it. Like you though, I think I've only got the larger stuff left over along with some spiral wrap.
Craig.
Michael
posted on 23/1/12 at 10:43 PM Reply With Quote
Yes thanks Craig.
I have looked at VWP and Polevolt and have found the same prices.
The bay has cheapest at £2.39 for a meter so not realy worth the worry, but knowing its usualy 63p a meter then there is one hell of a mark up, but that will include postage grrrrrrrr.
PSpirine
posted on 23/1/12 at 10:44 PM Reply With Quote
Just had a rummage - sorry matey, can't find anything other than 5-6" off-cuts so must've used it all!
Michael
posted on 23/1/12 at 10:46 PM Reply With Quote
No its ok, thanks for the look and unless you live in the garage, thanks for going out to look too.
omega 24 v6
posted on 23/1/12 at 11:10 PM Reply With Quote
I have a bit I could post you.
designer
posted on 23/1/12 at 11:12 PM Reply With Quote
Maplins? RS components?
Mr C
posted on 23/1/12 at 11:23 PM Reply With Quote
I've a load, its not split, I cut it if required. I'm in Kent (Tonbridge way) if thats any good to you.
Girl walks into a bar and asks for a double entendre, so the barman gave her one
Michael
posted on 24/1/12 at 09:48 PM Reply With Quote
Thanks Omega, you have a u2u.
