Author: Subject: 1300 x-flow
killieaitken
posted on 25/1/12 at 12:23 AM Reply With Quote
1300 x-flow
Hi there, i am new to this feed and new to kit car building! I was wondering if anyone can help me out.....should me weber carbs be piped in with a return fuel line?
Can the carbs be fitted upside down as my throttle linkage is sticking up above my bonnet line? I really am usueless and if anyone has any photos of there competed x-flow engine with twin 40 webers plugged in etc it would be greatly appreciated!
chrisbeale
posted on 25/1/12 at 07:03 AM Reply With Quote
Hi, welcome.
No, I'm afraid you can't fit your carbs upside down, they wouldn't work. You shouldn't need a return fuel line either. I'm afraid if they stick up above the bonnet line you might have to think about modifying your bonnet. Alternatively, look into getting some different carbs.
lsdweb
posted on 25/1/12 at 07:46 AM Reply With Quote
Welcome
You used to be able to get Webber throttle linkages that mounted below the carbs - I've not seen them for a while though!
Wyn
Autosri
posted on 25/1/12 at 08:49 AM Reply With Quote
What sort of linkage do you have as the 40s on my pinto the linkage is in line with the spindle not above
It would be better if you put a pic up of yours then people can advise
Alan M
See picture below: Webber installation is very similar
(Not too good at this so pic might not show, have a look in my archive
stevebubs
posted on 25/1/12 at 09:03 AM Reply With Quote
1) No
2) No
3) Have you looked at other linkages?
http://www.locostbuilders.co.uk/photos.php?action=gal&user=stevebubs&folder=Fury%20Engine%20Bay
Dellortos not Webers but the principle is the same
[Edited on 25/1/12 by stevebubs]
killieaitken
posted on 25/1/12 at 11:39 AM Reply With Quote
It is orginial webber throttle linkage kit, Can it be fitted on any one of the webbers r does it need to be the furthest away? The funny think it the car is built out of the ron champion book so the carbs should fit the body work. I will take a picture today abd get it up loaded
