Author: Subject: where best to take water temp
Murphy
posted on 26/1/12 at 03:00 PM Reply With Quote
Hi
fitting water temp gauge on R1 carb model. Where is best to take the water temperature from. Where to locate the sender.
Many thanks
mark chandler
posted on 26/1/12 at 03:14 PM Reply With Quote
Where it exits the engine for a gauge, so if you cannot plumb just before the thermstat then fit in the top hose.
jossey
posted on 26/1/12 at 03:23 PM Reply With Quote
just before it goes into the rad. (not out)
David Johnson
posted on 26/1/12 at 04:04 PM Reply With Quote
Yes a gauge should go in the engine water outlet before the thermostat if that is not suitable anywhere in the cylinder head, or in the coolant by-pass circuit
[Edited on 26/1/12 by britishtrident]
Murphy
posted on 26/1/12 at 06:04 PM Reply With Quote
Many thanks everyone
renetom
posted on 5/2/12 at 10:22 AM Reply With Quote
waterworks
Hi
This is the layout we used & works perfectly.
(See waterworks sketch on our photo archive)
Hope it helps.
carnymouse
posted on 9/2/12 at 10:08 PM Reply With Quote
BEST PLACE IS JUST BEFORE THE WATER ENTERS THE RADIATOR
carnymouse
