Author: Subject: another zetec question
Mday41
posted on 1/2/12 at 04:16 PM Reply With Quote
right i no theres alot out there about wiring up the zetec i have a 1.8 silvertop EEC-IV ecu out of an 1998 escort gti i have most of the loom and im thinking of stripping the loom down to the bear essentials i have key and transponer i have the pin out diagram for it but wondering if any1 no's whats needed and wots not!.im not using the injection as bike carbs will b fitted. was going megajolt or emrald ecu do use the original too? any help would b appreciated.
m.day
bbwales
posted on 1/2/12 at 04:57 PM Reply With Quote
On my build I used Megajolt to save the problem of making/modifying the original loom. Megajolt is used by itself and has caused me no problems and I am very pleased with the install.
Regards
Bob
lewis
posted on 1/2/12 at 05:19 PM Reply With Quote
+1 for mega jolt they sell as a zetec pack with all the bits you need and a basic map for around £200
I am a driving god!..........sort of
Mday41
posted on 1/2/12 at 05:31 PM Reply With Quote
thanks guys so what your telling me is have no need for the loom or ecu and the megajolt will replace it all?
m.day
bbwales
posted on 1/2/12 at 05:38 PM Reply With Quote
Yes that is correct.
Bob
Mday41
posted on 1/2/12 at 05:45 PM Reply With Quote
im so relieved cos looking at that ecu pin out digram and loom my head was scrambled thanks again guys! i always get the answer on hear i posted it on haynes forum first few days ago but no1 replied! can always count on the locostbuilders for answers!!!!!
m.day
AdrianH
posted on 1/2/12 at 05:58 PM Reply With Quote
Not sure if I will be correct, but you are using a 98 reg engine. Will the car not need to have a CAT fitted, will it be OK without if say you get a Q plate.
I understood it to be a pre 95 reg engine was OK without cat po9st needed one. So if running Megajolt with carbs will it be OK?
Adrian
Edit to say noticed not saying a 98 engine, just a 98 ECU.
[Edited on 1-2-12 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
big_wasa
posted on 1/2/12 at 06:35 PM Reply With Quote
98 should be eec-v and has 104 pins.
And if there going begging for not much dosh let me know
Mday41
posted on 1/2/12 at 07:56 PM Reply With Quote
I'm pretty sure a cat wouldn't effect it but I may stand corrected! I'm thinking Of fitting one just incase anyway, The escort gti was P reg 98 and the ecu is 60pin and has eec-iv written on it, the only reson I went for the 98 was that it was a gem of a find on 8000 miles off a mate of mine.
m.day
big_wasa
posted on 1/2/12 at 08:17 PM Reply With Quote
If your putting the engine in a car that will be IVA'd then it will need a cat and in my opinion will need injection to meet the test.
Some say you could get the engin through on carbs but I doubt it.
Ultra low miles that, not even run in.
I have tested a zetec on carbs with an eec-v but only as a complete loom. Never did try and see what the min amount of sensors are.
http://youtu.be/oVXW1fWn-l0
I am guessing
crank
Tps
Ect
Like most 3d ignition ecu's
Cam phase
Lambda
Maff
Will be needed for injection aswell.
Mday41
posted on 2/2/12 at 11:07 AM Reply With Quote
o right i do have two sets of throttle bodies wich i was going to use before i changed my mind as i thought it would b more complicated to set up i even have an st170 manifold wich i was going to use for them, im not to sure now! im not to fussed about fitting either but am worried about wiring it all up and was keen when i heard all i need is the megajolt kit to get the carbs working on the zetec! am i right in saying that if i use the tb's do i still need the loom an ecu cos im not feeling to confidant in setting that up myself! i have even thought of changing engine to cvh just for iva but having the zetec in and fitted and engine mounts made, i feel as if im going backwards if i do! aswell as having to cut out the engine mounts wich im very pleased with!
m.day
