Author: Subject: HELP needed...........
RMarine
posted on 2/2/12 at 07:40 PM Reply With Quote
I am having real trouble with my dash electrics. i cant figure out how the indicators work or the head lights.. if someone can help me there are cupboards full of cakes and tea at my house (in luton).
Its all Mark Evans fault......
snowy2
posted on 3/2/12 at 10:37 AM Reply With Quote
Indicators are very easy to wire up as are the hazards if you find a link to the wiring article i have posted on here it explains them in an easy way...
basically.....ignition switched live to indicator relay then to hazard switch then to feed position (middle) on indicator switch.....the other two wires are left and right indicators.
then a permanent live to the hazard relay then to the haz sw. the haz sw. will turn on both left and right indicators.....
sometimes you are the pigeon, most of the time the statue.
snowy2
posted on 3/2/12 at 10:42 AM Reply With Quote
http://www.godspeed.me/forums/viewtopic.php?f=14&t=1058
Read this.......it will help you....
or contact me at 07850773394 i may be able to help over the phone.
scudderfish
posted on 3/2/12 at 11:04 AM Reply With Quote
Are you using stalks or toggle switches? If stalks, which ones?
Regards,
Dave
monkeyarms
posted on 3/2/12 at 12:51 PM Reply With Quote
The PDF file in snowys link was a godsend to me, I have wired up my indicators and lights from scratch using it. It was very easy to follow, and should be of help to you. Here are the lights and indicatior diagrams from it, but i would recommend reading it all.
[Edited on 3/2/12 by monkeyarms]
DJT
posted on 3/2/12 at 01:07 PM Reply With Quote
I got stuck on my indicator wiring. In the end I had to draw it all out to make sense of it. Then it was much easier to fix. Maybe some help:
http://tigeravonbuilddiary.blogspot.com/
snowy2
posted on 4/2/12 at 07:01 AM Reply With Quote
Thank you for the vote of confidence Monkeyarms, i often wonder if anyone other than myself has tried to rewire their cars using my circuits.
monkeyarms
posted on 4/2/12 at 08:29 AM Reply With Quote
I wondered who made that wiring document. If it was you snowy2 then thank you, it gave me so much information and confidence to tackle the wiring. Now I feel a little bit of pride that "I did that" when asked about my wiring
snowy2
posted on 4/2/12 at 07:49 PM Reply With Quote
i am glad it achieved what i had hoped, i don't get to find out in the normal run of things. Dave.
