Author: Subject: What am I doing wrong now?
theduck
posted on 19/2/12 at 02:12 PM Reply With Quote
Am trying to put my engine in and can't get the gearbox to go on
Box is in car, can get the shaft part way in but not all the way in any suggestions??
Snuggs
posted on 19/2/12 at 02:15 PM Reply With Quote
Clutch plate not centred correctly.
Input shaft need turning slightly.
Needs to be wiggled a bit.
Did they mate correctly when out of the car ?
[Edited on 19/2/12 by Snuggs]
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
posted on 19/2/12 at 02:22 PM Reply With Quote
If there's nothing obviously awry, then as Snuggs says... give it some wiggle!
It's Evolution Baby!
theduck
Clutch etc as it was when came out of mk5 cortina.
Not had box on this engine before as just taken old Sierra engine out.
Daft question, how do I rotate input shaft? And will turning engine over by Han produce same result?
Been wiggling a lot already...
PAUL FISHER
posted on 19/2/12 at 02:35 PM Reply With Quote
Put the gearbox in gear, this will help you.
tegwin
posted on 19/2/12 at 03:04 PM Reply With Quote
Car in gear.... wedge one rear wheel and turn the other... will rotate input shaft.... get help to do that whilst you wiggle...
www.verticalhorizonsmedia.tv
CRAIGR
Contributor
Posts 2754
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 19/2/12 at 03:08 PM Reply With Quote
I take it the centreplate is the correct one and will fit the input shaft ??
[Edited on 19/2/12 by CRAIGR]
theduck
posted on 19/2/12 at 03:23 PM Reply With Quote
Never even thought to check, thought they were the same, they aren't
Problem solved though, need to change them over now... Help?!
Edit. I Sussed it
[Edited on 19/2/12 by theduck]
theduck
posted on 19/2/12 at 03:56 PM Reply With Quote
Anyone know if I can use the Sierra clutch and cover on the cortina flywheel?
posted on 19/2/12 at 04:58 PM Reply With Quote
Depends
2 diiferent sizes of both Cortina and Sierra clutch pressure plates (clutch covers).
Driven plates for the Sierra boxes come in 2 diffrent diameters.
Cortina V used 2 different spline patterens on the gearbox one is the same as the Sierra one isn't -- so 3 different driven plates.
You need to take the clutch over off check the number of splines AND the condition of the clutch, you also need to check the fingers on the clutch pressure plate are the same type as the Sierra if OK reassemble and re-centre the diven plate using an alignment too,
theduck
posted on 19/2/12 at 05:11 PM Reply With Quote
Sierra clutch was much larger than cortina so swapped fly wheel and clutch over onto the cortina lump.
theduck
posted on 19/2/12 at 06:00 PM Reply With Quote
And I still can't get it on . Going to wait until I have another set of hands to help as I am just going to end up hurting myself or the car.
Andy if you read this I hope youdont mind me holding onto your hoist?
