<<  1    2  >>
Author: Subject: What stock 4 cylinder engines can do circa 300bhp?
scudderfish
posted on 27/2/12 at 04:20 PM Reply With Quote
My current engine only has 4 injectors, and I think the ones I've got will not flow enough for the new engine. I need to know of some 4 cylinder engines that do 250-300bhp as standard so I can go searching the wilds of ebay for some new ones.
Regards,
Dave
HowardB
posted on 27/2/12 at 04:27 PM Reply With Quote
there was talk of saab injectors for 300hp on here, I am sure the gentleman with the mighty twin charged kitten would know the answer,..
Howard
beagley
posted on 27/2/12 at 04:38 PM Reply With Quote
IIRC there are some Subaru lumps that have that kind of power output, albeit with a large turbo, but they should be able to provide you with the necessary injectors.
Also, the Mitsubishi Lancer EVO is another 4 cyl that comes from the factory with those kind of levels.
Definitely not locost options, but they come from the factory which means they are probably developed for much more than those figures. You could also go through the math equations that will calculate the size of the injectors that you need. I'll see if I can dig those up for you. Hope this helps.
Beags
[Edited on 2/27/2012 by beagley]
I'm not scared!!! I'm just marking my territory.
whitestu
posted on 27/2/12 at 04:41 PM Reply With Quote
Porsche 968 turbo S?
Variant
968 Turbo S
Engine
Front longitudinal inline four cylinder water cooled 8v, KKK Turbo
Capacity
2990 cc
Max. Power
305 bhp (350 bhp for Turbo RS
Stu
[Edited on 27/2/12 by whitestu]
marco
posted on 27/2/12 at 04:55 PM Reply With Quote
Nissan 1.8CA Turbo, cheap to buy and tune and stage 2 will be circa 265bhp
MakeEverything
posted on 27/2/12 at 04:57 PM Reply With Quote
Dave, have you calculated the fuel flow? I can help you identify the flow and have a list of every Bosch injector and it's flow rate to select the right one if you want.
Kindest Regards,
Richard.
T66
posted on 27/2/12 at 05:01 PM Reply With Quote
1999/2002 Saab Aeros (HOT )have the B205r engine, the 205bhp model, I had mine up round 300bhp with the stock injectors.
Froggy will help you out , he is well read on Saab stuff.
http://www.ericsaabsite.com/Upgrades.html
[Edited on 27/2/12 by T66]
fesycresy
posted on 27/2/12 at 05:02 PM Reply With Quote
Cosworth
beagley
posted on 27/2/12 at 05:12 PM Reply With Quote
I dug up my book Supercharged! by Corky Bell and while you're not talking about forced induction there is a pretty simple calculation that will give you a rough idea of the size injectors that you need. The formula is:
Injector Rating in Pounds/Hour = ( Maximum bhp x .55) / (Number of injectors) @ 100% duty cycle
The problems is that the figure ".55" is the BSFC used for supercharged engines at full load. I did some quick searching, and didn't find a figure for a N/A car. It also mentions in the book that you want your injectors to run at about 80% duty cycle for best effect. So.... if my math teachers were any good.... we have...
(250 bhp x .55) = 137.5, 137.5 / 4 = 34.375 lb/hr, divide by .8 (80% duty cycle) = 49.96875 lb/hr
(300 bhp x .55) = 165, 165 / 4 = 41.25 lb/hr, divide by .8 = 51.5625 lb/hr
So it seems that around a 50 lb/hr injector would be the appropriate size. There are many other formulas, fuel pressure, pump requirements, etc... but I am using this as a "ball park" guess that you can use to get the appropriate size.
PLEASE anyone correct me if I'm wrong!!!
Beags
matt_gsxr
posted on 27/2/12 at 05:30 PM Reply With Quote
x10.5 to convert from lb/h to cc/min
That means ~500cc/min
Slimy38
posted on 27/2/12 at 05:45 PM Reply With Quote
I'm 99% sure the 1.8 turbo engine present in hundreds of different VAG cars can be tuned to beyond 300BHP but still use stock injectors. They only start out at between 150 and 250 BHP as stock, but the increase to 300+ does not involve a change of injectors.
Look at Skoda VRS, SEAT Cupra, VW GTi's of various forms, Audi use it across their range, etc.
Volvorsport
posted on 27/2/12 at 06:34 PM Reply With Quote
cosworth 804's
the saab injectors could be used , it really depends on what you actually need .
you need to size so that at 80% duty cycle your making 300hp ....
www.dbsmotorsport.co.uk
getting dirty under a bus
Dopdog
posted on 27/2/12 at 06:39 PM Reply With Quote
would you not use 400cc injectors?
coyoteboy
posted on 27/2/12 at 06:45 PM Reply With Quote
Staying within limits I can confirm from experience toyota 3S-GTE injectors (MR2 turbo, Celica GT4) can do about 280hp at stock pressure (440cc) and 340ish with the later spec 550s in that engine. They are side-feed though.
You can buy some nice Injector Dynamics 1000cc ones for about £100 a piece.
tony.g
posted on 27/2/12 at 07:19 PM Reply With Quote
Lotus Esprit S4S or sport 300.
scudderfish
posted on 27/2/12 at 08:17 PM Reply With Quote
Thanks all, plenty of food for thought.
iank
posted on 27/2/12 at 08:53 PM Reply With Quote
Another approach, though it would likely work out a little more costly is to use 2 injectors per cylinder in an under and over rail, easy to find 150bhp injectors.
I've read somewhere about it being an advantage since the spray patterns would tend to have smaller droplets and a better fan shape (could just be the internet talking though)
Anonymous
gremlin1234
posted on 27/2/12 at 09:13 PM Reply With Quote
"(250 bhp x .55) = 137.5, 137.5 / 4 = 34.375 lb/hr, divide by .8 (80% duty cycle) = 49.96875 lb/hr "
err, no its
=42.96875 (not 49...)
beagley
posted on 27/2/12 at 09:18 PM Reply With Quote
err, no its
Thanks for that catch..... I think this may be a case of my head going faster than my hands. Although my friends at work tease me about being dyslexic sometimes, I'm beginning to wonder if they are correct!
Beags
perksy
posted on 27/2/12 at 09:19 PM Reply With Quote
SAAB Turbo 'Reds' would be worth a look
Whichever ones you choose in the end make sure they are the right Impedence for the ECU you are using
turboben
posted on 27/2/12 at 09:53 PM Reply With Quote
I ended up with some 525cc (50lb) corvette injectors. They must be z7 or something really tasty. The best thing is you can pick out the best and stick the remaining 4 back on ebay! Made it a cheap way round for me.
MakeEverything
posted on 27/2/12 at 10:02 PM Reply With Quote
Dave, look at me injector uk and ASNU injectors if you're looking for performance. I can put you in touch with Steve to discuss e benefits.
Kindest Regards,
Richard.
jeffw
posted on 27/2/12 at 10:06 PM Reply With Quote
Variant
968 Turbo S
Engine
Capacity
2990 cc
Max. Power
Stu
lol, good luck with that search, there where only about 10 made.
froggy
posted on 27/2/12 at 10:42 PM Reply With Quote
Stock Saab reds are good for 280hp at 3bar 80% duty . If your motor takes the same size a set of 630 siemens deka as fitted to most tuned 1.8t vag motors will give good control low down and support 400+ hp no problems . I have run the 870cc version of the same injector with no issues at very low duty .
I've got plenty of reds if you want a set , just cover the postage .
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
westy turbo
posted on 28/2/12 at 11:32 AM Reply With Quote
Vaux can easy do it!
<<  1    2  >>
