Author: Subject: intercooler pipes
beaver34
posted on 27/2/12 at 08:12 PM Reply With Quote
intercooler pipes
im using 63mm or 2.5" hard pipes, i will need to make some intercooler hoses to join the silicone ends on my engine build
can you buy a tool the bead the ends of normal pipe? as cooler pipes on eBay seem really expensive
what have you guys done?
thanks
madteg
posted on 27/2/12 at 08:30 PM Reply With Quote
Mine are just clamped on to straight pipe, i am running 15PSI and they have not blown off yet.
beaver34
posted on 27/2/12 at 08:38 PM Reply With Quote
im looking at running 20 psi, just dont want the hassle, first place its going is london on a trailer to get mapped carnt afford it to go wrong
imp paul
posted on 27/2/12 at 08:46 PM Reply With Quote
i made this tool and it works sweet to put a bead on pipe home made locost style pipe sw
all you need is 1 mole grips
2 exhaust clamp
3 very thick steel washer weld both to the grips as above and as you can see it does a nice job on steel tube cheers paul
[Edited on 27/2/12 by imp paul]
macc man
If the pipe is of a thin gauge you could use an Oyster tool to form a bead. Used to be on sale in B&Q but getting hard to find now.
mark chandler
posted on 27/2/12 at 08:47 PM Reply With Quote
You can easily make a beading tool, just modify an old pair of mole grips.
If you have a google you will see hand held jobs they just have a ball and socket, so grind up a stamping edge and socket in the jaws.
Regards Mark
Chippy
posted on 27/2/12 at 10:51 PM Reply With Quote
In one of Dave Walkers write ups in PPC he just tapped three outward facing dents in the end of the pipe, seemed to work for him. HTH Ray
rdodger
posted on 27/2/12 at 10:53 PM Reply With Quote
Intercooler pipe beader | eBay
westy turbo
posted on 28/2/12 at 11:34 AM Reply With Quote
merlin and many others have them in different bends,angles. or u need custom do them?
beaver34
posted on 28/2/12 at 11:46 AM Reply With Quote
need to custom them, and that work sout cheaper as far as i can see
