Author: Subject: Which GRP Seats Have Gel-Coat on the Rear
posted on 1/3/12 at 07:06 PM Reply With Quote
My biggest bug-bear about most kit-oriented GRP seats is the nasty rough finish on the rear and sides.
Does anyone know of any manufacturers who gel-coat all faces?
It's Evolution Baby!
twybrow
posted on 1/3/12 at 07:12 PM Reply With Quote
The method they use to make them, there is little advantage other than making it the same colour. It will never have the same finished surface look as it isn't a moulded surface....
Buy a pot of gelcoat (well flowcoat really) and apply it yourself!
plentywahalla
posted on 1/3/12 at 07:13 PM Reply With Quote
Technically the finish on the back would be a Flo-coat. Mix of Gel-Coat, Resin and Paraffin Wax.
Most manufacturers wouldn't do it because it adds weight without adding strength. a better solution would be surfacing tissue. Not as smooth but much lighter.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
posted on 1/3/12 at 07:14 PM Reply With Quote
Cheers... is it that straightforward?
loggyboy
Judging by the pics ive seen of JK ones, some of them look gloss, maybe its an option?. (not the pics on their site btw as they are all low res front shots)
[Edited on 1/3/12 by loggyboy]
twybrow
posted on 1/3/12 at 07:22 PM Reply With Quote
Yes - mix it with 2% catalyst, and apply like paint.... Voila!
posted on 1/3/12 at 07:24 PM Reply With Quote
Well hurrah and huzzah (whatever that actually means!). Will give it a go when the time comes!
daviep
posted on 1/3/12 at 09:11 PM Reply With Quote
Another option would be flocking.
Davie
loggyboy
posted on 1/3/12 at 09:17 PM Reply With Quote
Vinyl wrap?
ashg
posted on 1/3/12 at 09:39 PM Reply With Quote
tillett...................................
will match carbon tub loverly jubberley tubberly.....
dont forget to buy the wrong size and sell them to me for half price before you get the correct ones.
[Edited on 1/3/2012 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Andybarbet
posted on 1/3/12 at 09:44 PM Reply With Quote
When I asked about Triton seats rear finish ages ago, he mentioned the option of adding some sort of paper to the back of the seat when they are made, apparently it gives a 'neater' finish.
Just found the reply:
'If you let me have your email address I will send you some pics of the backs but the standard finish is matt....I can however finish the backs as per the superlite seats with surface tissue which gives a much nicer smoother finish. £5.00 per pair extra for the tissue'
I did ask for some pictures but never got them.
Has anyone else got Triton seats with this finish on the back ??
Im going to go for GRP seats when i get round to needing seats (probably about 5 years judging by current progress) but i am with you on this one scootz, it would be nice to have a neater finish on the rear, especially as im short because the driver seat will be well forward of the interior ali back panel.
ReMan
posted on 1/3/12 at 10:31 PM Reply With Quote
Does nobody do the "double skinned" seats anymore?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Davegtst
posted on 1/3/12 at 10:37 PM Reply With Quote
I wish I was given this option. I have triton seats and the rough finish on the back really let them down.
Chippy
posted on 1/3/12 at 10:51 PM Reply With Quote
Well not quite, for a start you will only be able to apply one coat due to the wax content, and very often that will come out too thin. What you need to do is apply a couple, or more, coats of gelcoat, they won't fully dry, but will stay tacky, once you have enough thickness, then apply a coat of flowcoat, this will set hard, and because it excludes air from the gelcoat that will set hard as well. Then get the wet and dry out, (400 grit), and cut back to a nice flat surface, then buff to a high shine. HTH Ray
twybrow
posted on 7/3/12 at 12:33 PM Reply With Quote
Crikey Chippy - he opnly wants a visual improvement, not to build massive thickness in the gel/flowcoat...
Yes - with flowcoat you typically only do one coat, but it usually covers very well - certainly enough in one pass to cover the worst of the csm matt print. If you want to build the thickness, dont bother with flowcaot, but instead buy gelcoat, and a small pot of wax to add to the gelcoat for the final layer...
Dont make it out to sound difficult - it really isn''t tricky stuff to use!
mabbs
posted on 10/3/12 at 09:32 AM Reply With Quote
I also wanted a smooth finish to the rear of my carbon fibre pre-preg seats. The easiest way to acheive this is to spray them. The process was to flat them back with 240 grit, then used a high build polyester based primer to get a smooth surface. They were as rough if not rougher than GRP seat backs before paint. Then finshed with the colour coat and lacquer. Went with the Mclaren chrome paint to fit the scheme of my car:
40inches
posted on 10/3/12 at 11:06 AM Reply With Quote
Wow! Superb!
posted on 10/3/12 at 11:21 AM Reply With Quote
Looks really good... who did you get the seats from?
andy996tt
posted on 16/3/12 at 07:54 AM Reply With Quote
JK composites seats dont have a Gel coat back but they have a very neat pattern which I think looks fine
mabbs
posted on 17/3/12 at 09:57 PM Reply With Quote
One of my customers:
http://streamlinecarbon.com/v2/products-page/seats/sc1-carbon-fibre-racing-seat/
Very good quality
