Author: Subject: rivnuts for seat
chris666
posted on 5/3/12 at 06:04 PM Reply With Quote
rivnuts for seat
Would rivnuts be good enough to bolt down the seat runners to pass the IVA?They would be inserted in 1"floor box section.
Chris
A1
posted on 5/3/12 at 06:15 PM Reply With Quote
id say so.. use m8 ones, theyll be fine.
Daddylonglegs
posted on 5/3/12 at 06:21 PM Reply With Quote
I personally would not like to think my seats are only held in by rivnuts I have used bolts through the chassis into the seats direct.
Just my personal opinion you understand
ReMan
posted on 5/3/12 at 06:25 PM Reply With Quote
H'mm whilst I'm sure they'd probably be OK spec wise, I think I'd prefer good old nuts and bolts.
The other train of thought though might be that the seat barely needs holding at all because the belts are holding it and the driver in place?
[Edited on 5/3/12 by ReMan]
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
loggyboy
posted on 5/3/12 at 06:41 PM Reply With Quote
decent size rivnut might mean pretty big holes in chassis. would probably be ok tho as seat doesnt do much.
bi22le
posted on 5/3/12 at 06:48 PM Reply With Quote
My track day seat is not bolted in at all. It sits on a metal cross frame to keeep its position and angle then its a very tight squeeze to get it to the bottom. Me on top plus harnessed in, it aint going nowhere!
Some thing tells me the RGB racers dont fix in their expanding foam seats either, how could they.
You must consider that neather are going through IVA.
Please read my ring story:
ashg
posted on 5/3/12 at 07:17 PM Reply With Quote
i failed my iva for securing a brake line pressure switch with riv nuts so i doubt you will pass sing them for a seat. i personally wouldn't feel safe using them for my seats.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
iank
posted on 5/3/12 at 07:30 PM Reply With Quote
But arguably the chassis rail will be...
OP: I certainly wouldn't use aluminium ones, but steel ones might be up to it (I'd talk to VOSA before using something that might be difficult to 'fix'.
Anonymous
loggyboy
posted on 5/3/12 at 08:38 PM Reply With Quote
On what basis?
mad-butcher
posted on 6/3/12 at 08:35 PM Reply With Quote
Rivnuts are great IF you really have confidence in how well you've fitted them, I've helped quite a few people with their car, and a few times I've had to suggest they drill them out and do them again
several reasons
overtightened, wrong type (I much prefer the serated ones) not tightened enough, ( I've had people say well the bolt tightened up OK but I can't get it out because the rivnuts spinning )
