nickw2000
| posted on 7/3/12 at 07:55 PM |
Battery recomendation please?
What battery will give me the greater starting power and even if the battery has had abit of a drain from
An electric reverse system on a BEC, That I can be confident my battery will start my engine back up after using it.
I was thinking odessey p680? Or a standard car battery with 330 amps?
Can anyone recomend anything please that's a reasonable price?
loggyboy
| posted on 7/3/12 at 10:22 PM |
Can you not just run the engine whilst reversing so the alternator does the hard work not the battery?
40inches
| posted on 8/3/12 at 08:11 AM |
That's a bit hit or miss I'm afraid, if the voltage drops below a certain point the ECU shuts down and the engine stops
nickw2000
| posted on 8/3/12 at 10:36 AM |
Im not bothered if I have to turn the engine of to reverse because it's only used once in a blue moon, but need a Battery that can withstand the
elec reverse and still have enough power to start the car back up
| posted on 8/3/12 at 10:40 AM |
Yep under heavy load even big fully charged healthy battery from diesel with a high ah and cca rating will get pulled down to 11v a normal
sized battery from a 1600 car will get pulled down to 10v and the largest large motorcycle battery will swiftly drop to 9v after a few seconds.
I
loggyboy
| posted on 8/3/12 at 10:54 AM |
Maybe just rev it when you reverse like you would if you were using a standard geared reverse?
| posted on 8/3/12 at 11:10 AM |
With reverse motor operating the voltage will plunge the bike alternator will try and pull the voltage back up by pumping out amps however
bike charging systems are much smaller, simpler and more fragile than car systems and they aren't designed push out massive amps. Also the
additional alternator load on the engine will make it stall as bike engines tend not to have idle speed control.
[Edited on 8/3/12 by britishtrident]
