Author: Subject: Zetec Loom plug Ident
tims31
posted on 10/3/12 at 04:51 PM Reply With Quote
After some help please guys, could you all with your wealth of knowledge please ident all the plugs on this zetec loom for me. I'm sure big wassa will be able to but if any of you can help that would be great, thanks
Zetec-ECU-Loom
Zetec-ECU-Loom
The Injector part has the ident 98BG-9H589
The main part is 97BG-12A522-CDB
[Edited on 10/3/12 by tims31]
Build: http://www.martinsfurybuild.co.uk/
AndyW
posted on 10/3/12 at 05:37 PM Reply With Quote
13) Crank position sensor
12) Water temp (One of two)
11) Cam position sensor
8) other water temp
5) O2 lambda sensor
4) 42 pin plug to car loom
3,2 & 1 again cant quite see but air flow meter, throttle position switch & bu&&er cant remember.
Will have a look at my spare loom later if I get chance
big_wasa
posted on 10/3/12 at 07:57 PM Reply With Quote
1) Coil
2) Supressor
3) Maff
4) C2513
5) Lambda
6) ------------------- Egr from memory
7) -------------------- Egr from memory
8) Coolant temp sensor for ecu
9) Idle controle valve
10) Throttle position sensor
12) coolant temp sensor for dash
14) Alternator
15) Low oil pressure
tims31
posted on 10/3/12 at 11:29 PM Reply With Quote
See, I was right. I knew you would know what they all were big_wasa
The big 42 pin plug (C2513) is that needed? Do I need elements of the car loom to get this to work? What about 6+7?
I have an OWLS ECU as you suggested with the key and sensor with it. Is this loom going to work ok with this ECU? I really need to pop round and see you again so you can take a look at this for your expert view.
Hows your Pre-IVA going?
big_wasa
posted on 11/3/12 at 12:47 PM Reply With Quote
pop around mate I am on the drive playing with mine.
AndyW
posted on 11/3/12 at 12:51 PM Reply With Quote
IVA booked yet Warren??
big_wasa
posted on 11/3/12 at 12:54 PM Reply With Quote
eeeeeeeeeerm no
i_froloshki
posted on 2/4/12 at 01:59 PM Reply With Quote
Originally posted by big_wasa
1) Coil
2) Supressor
3) Maff
4) C2513
5) Lambda
14) Alternator
one question from me as well - what should i do with the C2513 item? I am using the zetec ECU with all its additional items - MAF, throttle, injectors and custom plenum. I am going to use dolphin gadgets and eddie 99 loom. The other thing is that i have to think of something about the air temp. sensor - where to put it. Any information will be helpful.
Yavor
big_wasa
posted on 2/4/12 at 04:19 PM Reply With Quote
You can cut the plug of car side and wire it into your loom or the way I prefer is to cut it up and custom re-build the loom to fit the car.
Air temp sensor will depend on what ecu you use. Its built into the Maf on the black top. On my silver top I stick them in the plenum.
[Edited on 2/4/12 by big_wasa]
