Author: Subject: Simple alternator tensioner
i_froloshki
posted on 11/3/12 at 12:51 PM Reply With Quote
Hi all,
i wanted to show you the bracket i made for my silver top. The problem was that i did not have any space to make the usual one and the alternator (nissan micra) had a 180 degrees tension point. So i came up with this solution.
It is absolutely easy to make (still a bit ugly cause it is not grinded and painted) and 100% effective (for now)
If anybody need more pictures - let me know.
regards
Yavor
tomgregory2000
posted on 11/3/12 at 12:57 PM Reply With Quote
i would fit a nut onto the bolt as a locking nut against the welded ones otherwise vibration will rattle free the bolt and your tension will be lost
Andybarbet
posted on 11/3/12 at 12:58 PM Reply With Quote
Great idea, no more leaning on a crow bar trying to do up a nut with the other hand
When i make mine i may have to 'borrow' your idea
designer
posted on 11/3/12 at 03:02 PM Reply With Quote
Yes, a lock nut is required.
MikeR
posted on 11/3/12 at 03:28 PM Reply With Quote
As well as the lock nut i'd be tempted to weld a large washer or something on the head of the bolt - something to spread the load over a larger area. The alternator aluminium will work harden, the larger the area the longer it will take before fatigue sets in and something breaks.
Ben_Copeland
posted on 11/3/12 at 03:32 PM Reply With Quote
I personally think thats a bad idea, as Mike says it'll put force on the alternator, cracking the case after a while.
Ben
Locost Map on Google Maps
Enter Your Details Here
avagolen
posted on 11/3/12 at 04:57 PM Reply With Quote
Hi Yavor,
I have attached a picture of my alternator tension - on a silvertop zetec.
It is similar to what you require as my alternator also had mountings at
180 degs.
This picture shows a nut as a temporary spacer.
Len.
Alternator_tensioner
Hope it helps.
i_froloshki
posted on 11/3/12 at 06:44 PM Reply With Quote
I have te nut, this was the trial fit. Onthe other hand the head fo the bolt contacts the alternator in the middle between the aluminum cases on the steel middle part of it and i think it will hold, only the time will show. I looked at the last picture and it is very nice, but i do not have the space because my throttle bodu is in this place
Thank you all for the ideas)
Regards
Yavor
