liam.mccaffrey
posted on 27/8/04 at 08:45 PM |
handbrake?
i am nterested to know what people have done in relation to handbrake? on middys
front wheeled handbrakes?
extra spot calipers on rear(both wheels or one)?
or somthing different?
i am using the front engine and gearbox combination from a daewoo nubira, it had been suggested that i could use the rear calipers on the front discs,
at the rear (if you know what i mean) but the way the handbrake works would prevents this
Build Blog
Build Photo Album
kb58
posted on 27/8/04 at 09:04 PM |
This probably doesn't apply to you (or anyone needed to go through inspection,) but I drove a car for years without one. Never had a problem,
either pointing the wheels into the curb, and/or leaving it in gear. Even my new car's handbrake hardly works...
In a case where you *have* to have one, how about welding a bracket to the upright (front or rear axle) and adding one of the small single-puck brake
calipers. Outside-the-box-thinking would include putting a real small brake disk and caliper on the *inboard* CV cup of one of the axles.
This'll work even better if the car has a LSD.
liam.mccaffrey
posted on 27/8/04 at 09:13 PM |
good idea, a moped brake disc and caliper or somthing like that, don't have lsd though
Build Blog
Build Photo Album
Viper
posted on 27/8/04 at 09:20 PM |
Not for a middy but front engine rear wheel drive
how about the same idea but instead of on the drive shaft put the disc on the prop???
with a middy,,,whats to stop you putting a disc on each drive shaft??
Jon Ison
posted on 27/8/04 at 09:21 PM |
could you use sierra or simular rear calipers with an adaptor, this would have to be made of course, golf ?
worth a look maybe..........
liam.mccaffrey
posted on 27/8/04 at 09:36 PM |
making adapter is not a problem i assume you mean use a caliper with in built handbrake function? any recomendations while i am at it should i change
the discs aswell i think they are vented jobbies from the abs daewoo as i will have mega brakes form the daewoo on the back and bog standard tinas up
fron
any news on the name of that supplier for poly rod jon?
Build Blog
Build Photo Album
Viper
posted on 27/8/04 at 10:00 PM |
What rear end are you using?
liam.mccaffrey
posted on 27/8/04 at 10:04 PM |
do you mean suspension wise?
custom wishbones, i havn't worked it all out at the rear yet.
Build Blog
Build Photo Album
turbo time
posted on 28/8/04 at 03:24 AM |
Yeah, I have the same problem...don't know what to do about a handbrake, I'm not sure I really need one, but it would be nice if I were to
install a turbo timer or remote start when the car has to be in neutral.....hey it's gonna be my daily driver
But I have a good plan involving a length of rope and a big heavy brick ![](/images//smilies/wink.gif)
Alan B
posted on 28/8/04 at 02:58 PM |
Guys check out this old thread on the subject...
http://www.locostbuilders.co.uk/viewthread.php?tid=2081
One of the first threads in the section..![](/images//smilies/bigsmile.gif)
posted on 28/8/04 at 04:33 PM |
Someone mentioned Alfasud.
The last post in that thread suggests the aforementioned. I had one and the discs were inboard on the gearbox before the uj. The handbrake was a joke,
I'd have slowed the car down quicker in an emergency by waving my hand out of the window.
[Edited on 28/8/04 by Peteff]
ned
posted on 31/8/04 at 11:49 AM |
you can get a small spot calpier from wilwood/rally design which si a little mechanical caliper, mount a disc on the inboard driveshaft end as already
mentioned..
Ned.
beware, I've got yellow skin
gys
posted on 13/9/04 at 09:46 AM |
Does anyone know where you can get the Brembo mechanical calipers for a reasonable price? Tried the Ferrari dealer since they use them, but they
charge $$$. Or an alternative that can run 22-25 mm wide discs... Wilwood has 20.6 mm max I believe.
I've got Porsche Monobloc 4-pot calipers for all around, but normally a drum brake within the disc is used for the e-brake. That's
unfortunately no option with the uprights.
The inboard calipers are a bit hard since I will certainly have some clearance problems. Secondly I don't like the idea of adding extra mass
(translation + rotation) while there already is a disc that is perfectly suitable for the job.
Man kann ein Auto nicht wie ein menschliches Wesen behandeln – ein Auto braucht Liebe...
MrFluffy
posted on 13/9/04 at 10:35 AM |
Handbrake calipers
Might be of interest, some motorbikes use mechanical disc calipers (honda cb100n, and some bigger ones too) and while they are mostly not very
efficient, they would serve the purpose of a handbrake caliper and are self adjusting (but you could defeat that if undesired).
Also, they dont use 20mm thick discs, but the design of them is such that its a easy job to make a thicker spacer between the caliper halves and space
them to suit..
On thinking about it, if you dont have one handy it might be more trouble than its worth ![](/images//smilies/smile.gif)
ned
posted on 13/9/04 at 10:45 AM |
just to reiterate the serperate spot caliper idea, we had a crawl over an 04 db9 at our reent newlands meet and spotted a spot caliper for the
handbrake in addition to the humoungous 4pot aston martin rear brake calipers..
gys
posted on 14/9/04 at 12:11 PM |
Porsche uses them also on the Carrera GT, I've seen them on the DB Vanquish, Spyker C8, and I believe they are also used on the Gallardo, some
Ultimas and some Lotus Esprits...
Movit uses them as well in their BBK rear kits. But is no company selling them separately?
As an E-brake they should be able to stop the car with a reasonable deceleration I think and whether a motorcycle brake is capable of stopping a 1200
kg (incl. driver, passenger, luggage) car then I doubt...
Has someone experience with the motorbike brakes on ventilated discs under circumstances mentioned above?
[Edited on 14/9/04 by gys]
violentblue
posted on 14/9/04 at 09:15 PM |
on my VW beetle witha porsche gearbox, I'm mounting another disc inboardbetween the output flange and cv joint, with a caliper from my old jetta
GLI (has mechanical pull for e-brake)
a single disc should be alright shouldn't it? otherwise I could do the second one the same way.
a few pics of my other projects
gys
posted on 14/9/04 at 10:41 PM |
Inboard is difficult since the differential housing is wider than the flange (measured from a vertical plane through the input shaft) on the left
site...
I have the original Girling 43 rear calipers, but I don't fancy using them along the 4-pots (rather heavy)...
Spyderman
posted on 15/9/04 at 10:41 AM |
Nope, you will need to fit the second one or it will only brake the one wheel!
Terry
Spyderman
violentblue
posted on 16/9/04 at 02:58 AM |
Terry
true, but if its only for an e-brake, then its not too big of a deal, still got the porsche brakes outboard, just going inboard (to avoid the nasty
design of the porsche e-brake, you know the drum within the disc) with the parking brake.
liam.mccaffrey
posted on 16/9/04 at 08:31 AM |
i still don't know what to do?
either mount a spot caliper on the existing disc
OR
put small moped disk and caliper inboard on the cv joint
Does it have to brake both sides or just one with respect to SVA?
Build Blog
Build Photo Album
turbo time
posted on 16/9/04 at 06:29 PM |
Lookadiss, I just found it (bottom of the page) I think it's perfect, wouldn't help you in an emergency situation if the regular brakes
failed, but it'd pass inspection and work for parking:
http://www.4agte.com/suspension_page.htm
Hugh Jarce
posted on 16/9/04 at 09:36 PM |
There are plenty of small mechanical callipers around, but these Airheart callipers offer the
largest number of variations. The lever can be orientated in a number of positions and there are clockwise and anti-clockwise variants.
The pay isn't very good , but the work's hard.
liam.mccaffrey
posted on 16/9/04 at 10:24 PM |
i am pretty sure that you have tyo have a mechanical "e-brake" to pass our SVA test
i am leaning toward spot caliper but do i need to do both back wheels?
Build Blog
Build Photo Album
gys
posted on 16/9/04 at 10:28 PM |
Installing a "line lock" is easier for the parking brake...
But I don't get away with that...
(hydraulic handbrake operating the same calipers neither)
The Airheart callipers are rather small
