Author: Subject: caterham alternator mount
Nitrogeno25
posted on 13/4/12 at 01:52 PM Reply With Quote
Does anybody use this bracket:
http://www.caterhamparts.co.uk/product.php?id_product=2415
It looks perfect for a 40a denso alternator (brise?) on the inlet side.
As the holes in these size are not aligned (bottom holes are aligned, but not upper ones) it is not easy to make a bracket and this is not very expensive.
Thanks!
big-vee-twin
posted on 13/4/12 at 02:17 PM Reply With Quote
I made one from billet alluminium here's a pick, just spent time and a lot of elbow greese getting it done hopefully you can see it in the pic
[img] Engine Bay cooling pipes
[/img]
http://www.triangleltd.com
Doofus
posted on 13/4/12 at 02:52 PM Reply With Quote
I've got one in the garage I never used if you want one.
£55 delivered sound ok?
Paul.
Nitrogeno25
posted on 13/4/12 at 02:55 PM Reply With Quote
[/img]
First thanks!
Mine looks different, I think I don´t have this bracket near the thermostat. I think the only way is using the holes highlighted. The upper holes are not aligned horizontally so is not so easy to get the alt correct. Not a problem withe the bottom holes.
The cater... bracket seem fine and if it works I would pay for it
Nitrogeno25
posted on 13/4/12 at 03:05 PM Reply With Quote
I found a picture that looks promising!
Mine is not really a brise alt, it's a daihatsu hijet 40a Denso thats look veeery similiar.
big-vee-twin
posted on 13/4/12 at 03:12 PM Reply With Quote
Just found another pic, I have used the bottom two holes and made a bracket for the bottom too from 4mm steel strip
[img] ND Alternator
ND Alternator
[/img]
