Author: Subject: Wing stays
theduck
posted on 20/4/12 at 04:31 PM Reply With Quote
Wing stays
I know this has been covered a lot but couldnt find the answers I needed.
Do different manufacturers wing stays fit differently?
If so who makes the simplest to fit? and how do they fit?
If they all fit about the same way, whose are best value? So not necesarily cheapest, but good quality and inexpensive?
This is all for a sierra based robinhood s7.
RK
posted on 20/4/12 at 04:44 PM Reply With Quote
I've done a bit of research on just this, and come to the conclusion that there are as many versions of wing stays as there are 7alikes. Maybe people could post pics of theirs and you can decide what would be best for your hubs.
scutter
posted on 20/4/12 at 05:16 PM Reply With Quote
I'm using the Cortina uprights, these are my 2 types i've used.
powder coating
powder coating
Using the 3 dust cover holes.
stripped
stripped
These use 2 dust cover holes and the lower ball joint.
ATB Dan.
theduck
posted on 20/4/12 at 05:17 PM Reply With Quote
That makes sense why it's so hard to find definitive information on them then.
Ideally I want something that will bolt on, further than that I havent given it much thought.
jiwillia
posted on 20/4/12 at 09:03 PM Reply With Quote
NTDWM used these on my haynes roadster and am well satisfied.
Kit Car Cycle Wing Stays, Mudguard Brackets | eBay
theduck
posted on 20/4/12 at 11:11 PM Reply With Quote
How do they attach?
jiwillia
posted on 21/4/12 at 06:21 AM Reply With Quote
Originally posted by theduck
How do they attach?
Fixing points are the lower wishbone ball joint and mushroom clamp bolt.
Cheers John
theduck
posted on 21/4/12 at 10:19 AM Reply With Quote
Thanks John,
They look pretty good.
Any other recomendations??
