jossey
posted on 20/4/12 at 08:01 PM |
1" 12swg steel needed anyone know who sells (not online)
So I'm struggling to get some more steel or my wishbones. I need 1" 12swg about 2 meters
Anyone got any.
David Johnson
Chippy
posted on 20/4/12 at 10:16 PM |
Have a look in Yellow pages for a local Hydraulic company, they use CDS tube, its what I did and got 2M of 25mm for a tenner. HTH Ray
jossey
posted on 21/4/12 at 06:38 AM |
Thank you.
David Johnson
John P
posted on 21/4/12 at 07:22 AM |
I was going to use Hydraulic tube but was advised by various people on here that it's a soft grade suitable for bending and what you need is a
mechanical grade.
Not sure if that's actually correct but I played safe and went to a merchant (unfortunately they're down in Devon).
John.
posted on 21/4/12 at 07:41 AM |
Proper hydraulic tube is tempered to bend easily, you don't have to have CDS for wishbones ERW is strong enough for the job,
Metals4U have it in stock although I have always found it at a local
stockist easily enough or they have ordered it in for me. Better Metals in Alfreton or Twiggs in Matlock are my nearest.
[Edited on 21/4/12 by Peteff]
iank
posted on 21/4/12 at 09:14 AM |
I agree with Peteff, but make sure you orient the seams correctly.
Metals4u also have it in CDS if you want to spend the extra
http://www.metals4u.co.uk/detail.asp?cat_id=162&prd_id=2927
Anonymous
degmwilliams
posted on 25/6/12 at 09:47 PM |
I just looked at that metals4u website, I can't believe how expensive they are. An 8x4 3mm sheet is £125.00, I can buy 3 sheets for that.
Building a tiger Avon st170 (slowly)
