Author: Subject: ST170 Cambelt change
Dave Bailey
posted on 23/4/12 at 08:57 PM Reply With Quote
All,
I have been reading the cambelt replacement process for the ST170 and I can't work out from the sketch where the locking pin goes in.. I states remove the blanking cover and insert the special tool. Anyone know where it goes before I bury my head in the engine bay to work it out?
Dave B.
ianjenn
posted on 23/4/12 at 09:24 PM Reply With Quote
its underneath the exhaust towards the crankshaft position sensor. The ST170 cambelt change can turn out to be a bit of a job and a half as when you tighten the inlet nut it can turn the VVT mechanism which means it is tricky to get them aligned. Send me a pm if you get stuck.
alex
Dave Bailey
posted on 23/4/12 at 09:29 PM Reply With Quote
Thanks Alex... I probably won't get to this for a few weeks because I have to work away for a bit....
I will be in touch if i have a problem...
Dave B
