andy o
| posted on 25/4/12 at 08:13 AM |
help alfa 159 airbag fault
i have a airbag warning light on the alfa159 and an mot due in six weeks.
have plugged a snap on diagnostic in and it has come up with the following code B103A
anybody got a book with the codes in it?
any help at all is very welcome
cheers
owelly
| posted on 25/4/12 at 09:38 AM |
I don't have a book of fault codes and the laptop that has my alfadiag installed has gone awol but I do remember a similar code on my 156 which
turned out to be a faulty multi-connector under the drivers seat. It's worth disconnecting the multi-plug and gicing it a good clean with
electrical contact cleaner (or brake cleaner) and check for damage or green pins. Also check the passenger side one too. Have you tried switching the
passenegr airbag off to see if that helps?
Good luck.
http://www.ppcmag.co.uk
Toprivetguns
| posted on 25/4/12 at 10:05 AM |
Am I right in saying all airbag fault lights are now a MOT fail ?
Only drive as fast as your angel can fly... !
PAUL FISHER
| posted on 25/4/12 at 12:15 PM |
Yes
andy o
| posted on 25/4/12 at 12:21 PM |
i have checked every connection i could find and have turned passenger bag on and off several times
have tried a couple of the alfa forums and am waiting for some answers
it is a mot failure and you can't take the bulb out as it is checked that the light comes on with the ignitoon and then goes out when you start
the car.
jamesbond007ltk
| posted on 25/4/12 at 03:14 PM |
The only reference to that code I can find anywhere on the internet is an Excel Workbook from the Czech Republic that contains a list of DTCs.
Couldn't tell you what Make or Model it is for I am afraid. If I have interepreted your code right the second number being zero indicates it is
manufacturer specific, so this may be of no help whatsoever, but just in case:
B103A 0x903A Thermoelectric Driver Overcurrent High
B103A 0x903A Right Front Seat Heater Sensor
Rich
[Edited on 25/4/12 by jamesbond007ltk]
Tell a lie, I have also found the following on an Alfa Forum:
B103A Front impact sens.
B103A Front lamp command
B103A Lumbar deflation button
Alfa Forum Page
| posted on 25/4/12 at 03:43 PM |
99 times out of a 100 it is one of the connectors under the seat but take care with airbags and pre-tensioner, turn the ignition off remove the
keys and wait 15 to 20 minutes before working on the --- keep the keys in safe place away from to prevent the buttons or transponder chip
activating anything Personally I preffer to have the battery disconnected.
Disconnect the sensors connectors under the seat clean with switch cleaner and disconect and reconnect a few times spray with contact grease
before finally reconnecting.
ssc28
| posted on 25/4/12 at 05:39 PM |
I'd suggest that you do what owelly says, it's almost always the case that a poor contact is the cause. Alfa techs usually also put a
cable tie round the thing once the connector is pushed back in to make sure it is held together tightly.
iank
| posted on 25/4/12 at 05:44 PM |
Any warning light (including empty washer bottle) is now an MOT fail.
If you have a vigilant tester he'll also notice if any don't come on that should when the key is first turned and fail you for a
non-working warning light.
Anonymous
