Author: Subject: re using megajolt??
shaft
posted on 29/4/12 at 06:31 PM Reply With Quote
re using megajolt??
Hi guys and gals, a bit of a techy question please...
I'm going to be swapping my Pinto for a V8 come this winter and have had a
bit of a thought.
The Pinto is running Megajolt (latest system) and I was wondering if its feasible to
re use this on the V8? Obviously I will need another coilpack but is it possible to get
the ECU re chipped to a 8 cylinder?
Nick.
my opinion might be wrong you know...
My Zero Build Pics
blakep82
posted on 29/4/12 at 06:34 PM Reply With Quote
yep, have a look at the autosportlabs website, i think you actually use 2 of the 4 cylinder coil packs, and an edis8, and use the megajolt configurator to set the cylinder number to 8
on the main 'tuning' page, click the 'options' tab, and select the number of cylinders
installation guide here
http://www.autosportlabs.net/MJLJ_V3_vehicle_installation_guide
and configurator operation guide here
http://www.autosportlabs.net/MJLJ_V4_Operation_Guide
[Edited on 29/4/12 by blakep82]
________________________
shaft
posted on 29/4/12 at 06:44 PM Reply With Quote
If Carlsberg made answers....
It would be this one!
Thanks muchly.
Does anybody have an edis8 unit for sale?
My Zero Build Pics
jonrotheray
posted on 29/4/12 at 06:45 PM Reply With Quote
Autosportlabs say it can be done - need EDIS8 and 2 coilpacks
see
[url=http://www.autosportlabs.net/MJLJ_V4_vehicle_installation_guide#EDIS_and_coil-pack_installation]Linky[/0url]
Too slowwwwwww!!
[Edited on 29/4/12 by jonrotheray]
posted on 29/4/12 at 07:02 PM Reply With Quote
Getting hold of an EDIS8 will likely be the most difficult problem, I don't think anything was fitted with them in the UK. You sometimes see them up for sale on Megasquirt or Megajolt Used EDIS8 EDIS 8 Unit & Plug with Pig Tail | eBay or you could buy one from the US.
[Edited on 29/4/12 by MikeRJ]
SPYDER
posted on 29/4/12 at 07:42 PM Reply With Quote
Is it not possible to use TWO EDIS4 units, each one running from two spark outputs on the MJ? Each EDIS4 can run its own 4 cylinder coilpack.
Just a thought.
posted on 29/4/12 at 07:52 PM Reply With Quote
Just a thought.
No. The EDIS gets it's engine position information from the VR sensor, connecting two of them to the same sensor would either provide two sparks at exactly the same time or quite likely wouldn't work at all.
I suppose you could fit two VR sensors, one mounted 180 degrees from the other. However, you would have to get the mounting exactly right and since the MJ can only accept one PIP input (the PIP output from one of the EDIS units would have to be ignored) and has only one SAW output (that would have to go to both EDIS units) there may be problems with synchronisation.
shaft
posted on 29/4/12 at 08:02 PM Reply With Quote
found a useful site for all things megasquirt / megajolt.
He has EDIS 8 units at £45 and it says good stock.
Thanks for the replies guys, you've cheered me up no end now
i know that it can be re used.
My Zero Build Pics
