robocog
posted on 6/5/12 at 07:48 PM |
Metal garage roof apex issues
Hey - not posted in a while
Garage is now up and it has a roof
...see my vids of it going up:-)
Garage build
part 1
part 2
part 3
Gone with metal sheet roofing in the end
I'm REALLY struggling on getting the apex on however and need suggestions
The sheet metal is a lot thinner and flexier than I had thought it would be so I don't feel I can trust walking on it
I did lean quite hard on one edge reaching across to fix one sheet down and it bent like it was made out of paper
(luckily managed to de-crimp it)
I only have good access to 2 sides - the other 2 edges are pretty tight up against flimsy fencing
Tried leaning a laddder across the roof angle (see dodgy diagram) but as you can see its not that simple
Had to use a pallet to support the other end and butted it up against another very flimsy fence
[img]
![](/galpreviews/dodgy apex fitting inc.JPG) ![Description](/gallery/dodgy apex fitting inc.JPG) Description
[/img]
Roof is plastic coated and slippery as a slippy thing...which doesnt help
I did put /some/weight on it in the above dodgy lash up and am convinced its going to buckle the metal roof if I put my body weight on it
There must be a simple and effective method (I don't have a cat to train in the use of a drill...besides they dont have thumbs)
Answers on the back of a postcard please
Regards
Rob
Edited to add
The apex is held on by self drilling self tapping screws through the upper part of each panels box section
[Edited on 6/5/12 by robocog]
MikeR
posted on 6/5/12 at 07:53 PM |
could you not take off all but the first roof sheet on you lawn side. Then reach up from inside the garage and fit the first bit of capping. Add the
second bit of roof, move down and secure the capping. Repeat untill complete.
zilspeed
posted on 6/5/12 at 08:31 PM |
You can certainly fix the ends without worrying about leaning on the mid section.
You'll get a good bit from the front and then the back.
I might be tempted to put a ridge in there to strengthen that zone and give something extra to fix to.
[Edited on 6/5/12 by zilspeed]
Bare
posted on 6/5/12 at 08:34 PM |
Something seems Odd.
Usually the Metal is seamed vertically, so Apex fitting is a non issue. Just stand inside the garage and apply the panels ..And.. the Apex ..
sequentially
What? did you Buy??
Hopefully you installed a full waterproof Membrane .. Under.. the tin bits??
Metal roofs Sweat heavily. Yup.. indoor rain.
Best get one of those hats with an umbrella on top, if not :-).
Bare
oops. sorry.
[Edited on 6/5/12 by Bare]
gazza285
posted on 6/5/12 at 08:40 PM |
Roof sheets should be fine to walk on, I'm guessing that you don't have enough purlins?
robocog
posted on 6/5/12 at 08:51 PM |
Good suggestion - but the apex covers the top rows of fixing screws for the sheets
and the apex is in 2 lengths each 3 m long
so the apex - at the moment - has to be the last to go on
There are only 2 angle iron supports per side running the length of the garage - and the apex is wider than the top pair so I had no choice where to
fix the sheets to so your suggestion could work if I cut the apex into smaller pieces and overlap them
Good call :-)
Will do that if nothing else turns up
Didn't see the other replies due to taking so long to compose the first reply..LOL
Zil - managed to get one apex piece on - as you say reaching across
I managed to get screws into the first meter by leaning across - now worried if we get high winds its going to write that piece off if it gets bent
Bare- its all screwed together (self drilling self tapping rubber washered doo dads) from the outside- roof sheets first and apex last - no other way
of doing it due to its design
gazza - yep just 2 skinny pairs of angle irons running each side and about 1m apart so definately not supported enough for this chubby chappie to walk
on...esp now they have lots of fixing holes drilled in them...LOL
Regards
Rob
Slimy38
posted on 6/5/12 at 08:56 PM |
Couldn't you support it from inside? Two of those extendible post things that builders use to support walls, with a plank or something across
the top under the roof. Then that should give you enough support to be able to get on top and fix the apex.
Alternatively, how about using some other form of fixing? I'm thinking something thick and sticky, then all you need to do is lay the apex on
top. Not 100% on that one though.
907
posted on 6/5/12 at 09:31 PM |
Could you lay a 3m central and cut the other in half?
Fix the 1.5m piece on working from the end? Same other end?
If you can reach to pop rivet the joints the centre 3m would need little fixing,
being held down by the 1.5m ends.
Paul G
designer
posted on 6/5/12 at 10:45 PM |
If your roof does not support a normal person, there are not enough roof supports.
Fasten the two pieces of apex together with an overlap then drop them on and fasten from each end as well as you can.
dhutch
posted on 7/5/12 at 07:27 AM |
How wide are the downs of the corugations, can you not get your foot into it there, standing on the perlins?
Daniel
norm007
posted on 7/5/12 at 08:13 AM |
In the past I have thrown a sheet of plywood and or several scaffold battens on top of sheets to spread the load.
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
robocog
posted on 7/5/12 at 09:44 AM |
Perlins are right at the top and bottom (so about a meter unsupported)
Cannot really get my foot into the lower part of the box section (even width wise) and I know I'll crimp crush the upper ridges without much
effort or weight
Have popped some pictures showing the construction up + showing how little I could do from the one end (those 4 fixings I managed to put in represent
3/4 of a meter - only another 4 and 1/4 meters to go!
I could probably go about a meter in from that end if I get some taller ladders on the case and some method of holding them off the overhanging roof -
so only one more pair of self tappers
[img]
![](/galpreviews/DSCF0009 lcb.jpg) ![Description](/gallery/DSCF0009 lcb.jpg) Description
[/img]
[img]
![](/galpreviews/DSCF0010 lcb.jpg) ![Description](/gallery/DSCF0010 lcb.jpg) Description
[/img]
The apex is wider than the top purlins (and covers/hides the fixings) so nothing to walk on there
The lower purlins are a lot lower than my feet - even if I would be happy with the apex wedged in my crack and sat splayed out- so the only parts I
can stand on are very much unsupported
Pic from when I started to dismantle it showing how the purlins run - again the apex is wider than the top purlins so it covers where the sheets
attach to them - also gives nowhere supported to stand
[img]
![](/galpreviews/DSCF3006 lcb.JPG) ![Description](/gallery/DSCF3006 lcb.JPG) Description
[/img]
I'm sure if I put some sheet wood to try and spread the weight I'll just slide off ski slope syleee (its very slippery - don't know
if they have coated it in PTFE or something despite the grippy looking leather grain patterns)
I thought the metal would have been thicker and stiffer so I didn't envisage these issues when ordering - assumed I'd be able to shuffle
along on my butt along the apex fixing it down as I went
Have someone who knows someone who does roofs - and waiting to hear back to see if they have any special ladders or euip or even advice
I may be able to borrow some acro props and wedge some sheet from inside...but then I'm not sure it helps if I daren't walk on the ridges
for fear of them crimping and crushing
Regards
Rob
dhutch
posted on 7/5/12 at 10:45 AM |
I can see you pain, and i dont know what the correct solution is, or what a roofer would do, give its too shallow for the hooks of a cat ladder to
catch. I would be thinking either a 4*4ft bit of of cut ply and some rubber on the back to stop it sliding (it really is quite flat, even if its
slippy a nutsack without something between them) or else back to the ladder and pallet!!
But some gloves on (ripped hands hurt, if it all goes wrong) and have a crack....!
Daniel
Nick DV
posted on 7/5/12 at 11:13 AM |
Get some scaffold board and wedge in place as close to the apex as possible using a cuple of Acrow jacks - make sure they cannot slip at the top and
bottom. Get another board and knock on a couple of pieces of batten to correspond with the channels and then lay the board over the one below so that
it sits above the ridges - if you know what I mean - protect the roof with a folded dust sheet if you want, and you should be able to quickly fix the
capping. Do this from both ends, work with someone who can check all stays in place below and you should be ok.
Chees, Nick
"The force will be with you, always!"
posted on 7/5/12 at 11:44 AM |
If I'm reading it right the problem is fixing the capping piece in place?? Why not do it from the inside? Drill some holes in the capping piece
every foot or so, use some long dome ended bolts through the capping hanging into the roof voice, put some metal bar (or even wood would do) between
those two bars which run the length of the garage, drill holes in the middle of them, bolt goes through the hole, add a nut and tighten.
IE clamp the capping piece in place using those bars that run the length of the garage as something to pull against.
If I've misunderstood please ignore the above ![](/images//smilies/smile.gif)
posted on 7/5/12 at 12:29 PM |
Why not take the trusses down and fit the roof to them then put it all back up in one piece ? I bet four of you could lift that and slide it back into
place.
owelly
posted on 7/5/12 at 12:43 PM |
INMO, if the roof won't take the weight of you walking on it, it won't last long with a couple of tons of snow on it! You'll need to
put up more steel work, some extra timber supports or be prepared to dash out every hour or so in the winter to sweep the roof!
Good luck.
http://www.ppcmag.co.uk
robocog
posted on 7/5/12 at 04:13 PM |
LOL, I doubt a couple of tons of snow have fallen on the whole of Gosport put together since the passing of the last ice age
Surrounded by the sea and protected by the IOW and the hills t'other side we hardly ever see it for more than a few seconds
We possibly had as much as 4cm of the stuff last year (most snow recorded evvvaaahhh) and my polyester tonneu cover on the Indy hardly sagged under
the "most extreme conditions" we saw and required no intervention from myself
Honestly - weight of snow is a complete non issue this way and it would be as daft as making the structure kangaroo proof
Sure - If I had the money or lived somewhere more prone to the white stuff I would have a much sturdier structure - but its survived the last few
dacades without collapsing so see no reason why it should suddenly do so
Even if it were to be subject to the next ice age and have its roof buckle and collapse- the worst case scenario would be my stuff getting wet
temporarily - no different to when I work outside and its raining (my only other option) - impact damage aside
Theres no way I'd be inside it if were to be snowing - I'd be a lot closer to some central heating and a kettle- so no loss of life would
occur in the worst case scenario
If it were a dwelling for my loved ones then yes - I would be a bit less casual about it
It's a shed to tinker in and to give the us the dining room back (looks like an autojumble in there)
Regards
Rob
robocog
posted on 7/5/12 at 04:58 PM |
Ben- thats how the original concrete asbestos ridges were held on
It could possibly be done like this again- but the new apex pieces have a neat creased/folded angle (pointy) and the old apex pieces were rounded so
sealing was less of an issue
The metal sheet is also wafer thin and I suspect it would buckle splay and deform before any "clamping" pressure could be put on it - so I
had kind of ruled that one out based on its flimsyness
I suppose I could make some special bolts (as per the diagram) and screw those to the apex and drop it through and nip up from below
[img]
![](/galpreviews/apex.JPG) ![Description](/gallery/apex.JPG) Description
[/img]
I also like the fact if it gets stitched every peak it will help make the whole structure all a lot more rigid so will carry on exploring doing that
(as suggested by the retailer)
Will ring them tomorrow and see if they have a neat solution - it's not like they wont have been asked a million times ..LOL
Regards
Rob
D Beddows
posted on 7/5/12 at 05:05 PM |
Google 'Sky Hooks' - they're what you need.....or just do it properly, there is no way you can do what you want to in the way you
want without that that roof collapsing as there is no support to it. Possibly you could tek screw from underneath but...
robocog
posted on 11/5/12 at 10:55 PM |
Well its done
I ended up just manning up and doing it
Turns out its perfectly fine to take my weight along the paper thin apex (I screwed the apex on as I shuffled along on my arse arms length away)
I guess I was basing it being way to flimsy on it not being attached to much, soon as a few more screws went in the structure felt much more solid
I had a "spotter" to make sure nothing was deforming/moving as I slowly went along
All is good and the man cave is pretty much waterproof
It lashed down on Thursday - so its had a very thorough test
Only leaks were from 2 miss drilled holes (easilly filled) and from around the outside creeping in under the walls
I may just haunch some concrete round the outside and silicone/bitchumen the inside
Would like to DPC and screed..but its possibly out of my budget and will delay getting the dining room back
Was great hopping onto a motorbike this morning and not having to wipe it dry first to try and avoid getting to work looking like I peed myself
Regards
Rob
