gixermark
| posted on 14/5/12 at 09:28 AM |
rocker cover breather on GSXR1000
Hi Guys,
the two breather outlets on the rocker of my motor were left open/exposed.. and i assume its where i am getting some oil coming from while on
circuit.....
my motor is dry sumped... question is - can i just link these two breathers together to let the oil flow back into the rocker - or does it actually
need to breathe ? in which case i need to get a T piece... link the two and vent into a breather/bottle ?
GreigM
| posted on 14/5/12 at 02:47 PM |
you need to let them breathe - the hose/t-piece idea would be fine - just make sure the catch tank itself can "breathe" as you need to let
the pressure out.....wouldn't be the first time someone has hosed breathers to an enclosed catch tank and the resulting pressure build up blew a
seal...
gixermark
| posted on 14/5/12 at 03:52 PM |
as i thought - cheers mate...... another small job to sort
progers
| posted on 14/5/12 at 04:54 PM |
quote: Originally posted by gixermark
Hi Guys,
circuit.....
Hi Mark,
Are you talking about the PAIR valve covers on the rocker cover? If so, these are there primarily to allow air to be scavenged into the exhaust on
throttle overrun, it helps to burn unused fuel and clean up the exhaust. For a race application, these are just blocked off with a blanking plate. It
has nothing to do with the good running of the engine when pressing on. All race bikes block these off, to no ill effect. You can alternatively just
bridge the two together with a pipe. Just remember to block off the hole in the original airbox (if you are using it), where the original feed to the
pair valve was connected.
- Paul
gixermark
| posted on 14/5/12 at 04:58 PM |
mmmn I'm not sure Paul...... i don;t think there are any open holes in the airbox that i noticed when i had it off - it is running the std
airbox with modified inlets to get ram air above my bonce..
i'll take the airbox off to have a proper look..
did you run a k5/6 before the K7/8 you are running now ? see my other threads on clutches - I know the K7 has changed a bit - but if you ran k5/6
I'd be interested in your opinion on whether to run the concave spring washer... or whether you took it out and put in a 'normal'
friction plate... i.e. not the larger internal diameter one to allow the cancave washer to fit into
progers
| posted on 14/5/12 at 05:15 PM |
Done!
You will probably find the airbox has had the hole blocked up already. Worth checking though. Blocking the pair valve off with blanking plates is
definitely the right thing to do. See here for an example http://gsxrzone.com/reedplates.html
Do you have the workshop manual? I can send it to you if you don't have it or download from here http://wotid.com/gsxr/content/view/22/43
Paul
[Edited on 14/5/12 by progers]
gixermark
| posted on 14/5/12 at 07:13 PM |
thanks Paul - i guess other than aesthetics... i could just link the two ends with a piece of tubing to block them off ! ? rather than buying these
I'm not too bothered about how she looks under there...
progers
| posted on 15/5/12 at 07:06 AM |
Yes that would work fine
- Paul
gixermark
| posted on 15/5/12 at 07:56 AM |
ta muchly.......
at least that will keep it cleaner !!
now need to get the clutch sorted...... electrical issue sorted.....
and i guess get the driveshaft replaced that broke too !!
