Author: Subject: zetec plus Eaton M45 (or similar)
contaminated
posted on 17/5/12 at 12:26 PM Reply With Quote
I've searched through lot's of threads but I'm struggling to find evidence of recent conversions. Has anybody currently got a car running with this setup? At this stage I'm just after a couple of people I might be able to PM in the near future. I need to work out plumbing, fabrication and throttle body (or modified carbs for that matter).
thanks
Dan
Tiger Super Six Independent
www.southernkitcars.com
djtom
posted on 17/5/12 at 01:06 PM Reply With Quote
Not supercharged, but my Super Six has a turbo'd Zetec in it if you want to have a look at air plumbing / chargecooler / etc??
Close to you, too!
contaminated
posted on 17/5/12 at 01:10 PM Reply With Quote
Close to you, too!
I would like to have a look at that Tom. The last time I saw your car was at Lyddon with the first incarnation of the turbo setup (before you pulled it all apart). Is it finished now?
djtom
posted on 17/5/12 at 01:16 PM Reply With Quote
In as much as it'll never be finished, yes!
It's been back on the road for a year now, and nothing has fallen off recently! There are a few more things I'd like to do, but I need a better clutch before increasing the power further as mine slips when I set the boost to anything more than about 0.8bar. Still goes pretty well at those levels though - at Lydden in March it was on par with a 280bhp duratec caterham. The westfield with a 'busa turbo lump was getting away from me though.
big_wasa
posted on 17/5/12 at 02:16 PM Reply With Quote
Ive seen a couple abroad on you tube. The problem with the eaton on a rh drive car is where to put it.
http://youtu.be/Ghjc_I1wQ-g
contaminated
posted on 17/5/12 at 02:37 PM Reply With Quote
I think I can fit it on the inlet side if I move the alternator to the exhaust side.
big_wasa
posted on 17/5/12 at 03:58 PM Reply With Quote
Will it clear the steering linkage ?
contaminated
posted on 17/5/12 at 03:59 PM Reply With Quote
With a bit of wiggling I think so. I need to mock it up.
Mave
posted on 17/5/12 at 04:32 PM Reply With Quote
I've almost finished my Indy rebuild, and part of it is the Eaton 45 conversion. It is running a Omex 600, and recently put out 218 bhp on the rollers. Things are pretty tight under the bonnet, but everything fits. My car is LHD though, and a steering shaft for RHD will need to take a different routing. But on the exhaust side things are pretty cramped as well, with alternator, idler pully, steering shaft, cooling hoses..... But on the rolling road it works perfectly. I'll post some pictures when my car is ready (should be within the coming weeks).
If you have any questions, let me know.
Marcel
contaminated
posted on 17/5/12 at 05:04 PM Reply With Quote
Marcel
Thanks Marcel. Sounds superb.
ChrisW
posted on 24/5/12 at 08:09 PM Reply With Quote
A mate of mine built a Fiesta mk1 with an E45'd Zetec in it. If there's anything specific you need to know about the engine I can ask him for you. Keep in mind his was FWD packaged though so there will be lots of differences.
Chris
My gaff my rules
contaminated
posted on 25/5/12 at 10:01 AM Reply With Quote
Thanks Chris - I'll work up a list! The main issues will be mounting it, putting the alternator back on the passenger side of the engine, pipework, throttle body and plenum. In particular I need to decide whether to start off with something like a ST170 throttle body or get some bike bodies.
Xtreme Kermit
posted on 25/5/12 at 09:51 PM Reply With Quote
Not sure if it helps but Quantum's current demonstrator has a supercharged zetec in it. Apparently it is really good to drive. CKC and TKC have given it good reviews. It uses an omex package as far as I know.
contaminated
posted on 28/5/12 at 11:30 AM Reply With Quote
Thanks mate, I'll have a look.
jeffw
posted on 28/5/12 at 01:09 PM Reply With Quote
You can come round and look at my Rotrex supercharged Zetec but I doubt it would be much help with your E45 version.
contaminated
posted on 28/5/12 at 01:15 PM Reply With Quote
Cheers Jeff, I may do that.
MakeEverything
posted on 28/5/12 at 02:13 PM Reply With Quote
I've done it to a Renault 21 engine if that helps. Details below.
Kindest Regards,
Richard.
